ᐅ Changing the layout of a Billy bookcase – how simple is it?
Created on: 22 Jun 2024 08:37
PAU48
I recently purchased the Billy bookshelf from IKEA and am quite satisfied with the basic design. However, I would like to modify the arrangement of the shelves to better fit my books and folders.
My question is: How easy or difficult is it to adjust the shelves on the Billy bookshelf in practice? Are there any special tools or precautions I should be aware of?
I am also interested in whether it is necessary to use the original holes or if it is possible to create entirely new shelf positions without compromising the stability of the bookshelf.
I would appreciate any experiences, tips, or potential pitfalls to consider when customizing the Billy bookshelf.
Paunon
22 Jun 2024 10:18
Simply unplug the shelves and insert them into a higher hole. No new holes are necessary. Make sure to distribute them evenly. This holds well and keeps the shelf stable.
pikin
22 Jun 2024 11:01
PAU48 schrieb:
whether the shelf loses stability as a result – especially if I want to stack heavy books at the bottom
The stability mainly depends on the proper overall assembly of the shelf. The spacing of the metal pins is designed so that the shelf does not have issues even with large shelf heights. However, it is advisable to secure the Billy shelf to the wall when the loads at the bottom are significantly increased to prevent tipping hazards.
U
usbla
22 Jun 2024 11:46
I would like to add that with higher-positioned shelves, you may sometimes notice fewer supports in the shelving unit, which can affect stability when the shelf is moved. So, if your shelf will be heavily loaded, you can secure a back panel for extra safety or choose a shelf with greater stability.
Additionally, the metal pins are not designed to support loads over approximately 15 kg (33 lbs) per shelf, which is important to keep in mind when stacking heavy books.
Jukin
22 Jun 2024 12:12
What is often underestimated during modification: The overall stability of the unit also depends on the connection between the side panels and the shelves. The fewer shelves there are, the fewer connection points exist.
If you are unsure whether the shelving unit is stable enough, you can add brackets inside the unit as a simple additional measure to reinforce the side panels.
Dilen
22 Jun 2024 14:06
usbla schrieb:
Metal pins are also not designed to support loads over about 15 kg per shelf
This is an important point. The pins hold less when they only penetrate a few millimeters into the particleboard. Under heavy load, it is advisable to distribute the weight across multiple shelves or add cross braces. Are you planning to store particularly heavy items or fill the shelves very densely? That could change the recommendation.
PAU48
22 Jun 2024 14:35
Dilen schrieb:
Are you planning to store any particularly heavy items or load the shelves very fully?
Yes, I mainly want to store a combination of books and binders. Binders are heavier and should be placed on the lower shelves, while the lighter books will be distributed on the upper shelves.
I also want the shelving unit to look tidy, which works better with fewer, taller compartments.
So, are brackets and back panels the most practical additions if I want to be on the safe side?
