I recently purchased the Billy bookshelf from IKEA and am quite satisfied with the basic design. However, I would like to modify the arrangement of the shelves to better fit my books and folders.
My question is: How easy or difficult is it to adjust the shelves on the Billy bookshelf in practice? Are there any special tools or precautions I should be aware of?
I am also interested in whether it is necessary to use the original holes or if it is possible to create entirely new shelf positions without compromising the stability of the bookshelf.
I would appreciate any experiences, tips, or potential pitfalls to consider when customizing the Billy bookshelf.
Adjusting the shelves in the Billy bookcase is generally straightforward: the standard shelves are supported by small metal pegs that fit into pre-drilled holes on the inside of the bookcase.
Normally, no tools are required; just a finger is enough to remove and insert the pegs. It is important to position the shelves evenly to maintain stability.
Drilling new holes should be done with caution, as this can weaken the shelf. If you disregard the original holes and drill entirely new ones, keep in mind that the bookcase is made of coated particleboard, which can chip or splinter when drilled.
I’m happy to add some extra information: The flexibility of the Billy shelf lies precisely in these small holes, which are spaced at regular intervals. They allow for different shelf heights.
A tip: If you want shelf heights where there is no existing hole, I recommend drilling a simple hole with a 5mm (3/16 inch) wood drill bit, as the pegs have this diameter.
Make sure the shelf is stable, especially if you plan to distribute heavy loads. For significant modifications, it may be advisable to secure the shelf additionally, for example, by anchoring it to the wall.
Additional to the topic of new drillings: The Billy shelf is made of finely laminated chipboard material, which is sturdy but requires very precise drilling to avoid splintering.
My recommendation would be the following approach:
1. Mark the new positions very accurately with a pencil and a spirit level.
2. Use a wood drill bit of approximately 5 mm (0.2 inches) diameter.
3. Drill slowly to avoid overheating or damaging the material.
Additionally, the small metal pins have limited load capacity. If you plan to store heavy items like thick books or binders, you should position the shelves so that the load is well distributed.
I would be interested to know: Are you planning only a few adjustments or a complete restructuring? That could affect stability and usability.
Dilen schrieb:
I was wondering: Are you planning just a few adjustments or a complete redesign?Thanks for asking. I mainly plan to rearrange the shelves to create some taller compartments – so fewer but larger gaps for bigger books and binders.
The number of shelves will likely be reduced rather than increased. I’m wondering if it makes sense to simply insert the pins into higher pre-drilled holes, or if this might compromise the stability of the shelving unit – especially since I want to stack heavy books at the bottom and store lighter items on top.
Summary and practical tips:
1. The shelves of the Billy unit can be easily adjusted without tools using the metal shelf supports.
2. If you only want to change the height, using the original holes is sufficient and provides the best stability.
3. Fewer shelves create taller compartment heights, which does not cause stability issues as long as the loads are distributed sensibly.
4. Arranging heavier books at the bottom and lighter ones at the top is ideal—the shelf is designed to handle such load distributions.
5. New holes can be drilled but should be done carefully with the appropriate tools.
If you move or readjust the shelf, the metal pins remain stable even after multiple adjustments.
