ᐅ Is it possible to refinish Malm furniture using spray paint?
Created on: 18 Mar 2021 10:17
Telibe
Telibe
18 Mar 2021 10:17
I have some Malm furniture from Ikea that I would like to redesign. They are now a bit worn and show signs of use. My idea is to refinish them with spray paint to achieve a smooth, even surface and a new color.
My question is: Can Malm furniture be refinished with spray paint? Are there specific preparation steps I should follow to ensure good adhesion and prevent peeling? Or is it generally not recommended because the surface might not be suitable?
I have read that Malm is actually made from a type of chipboard with a foil coating – this makes me unsure if spray paint will adhere well enough.
I would really appreciate detailed experiences or tips, especially regarding the process (sanding, priming, etc.). Thanks!
Mufato
18 Mar 2021 11:02
You should lightly sand the furniture first to help the paint adhere better. Then apply a plastic-based primer. After that, you can apply the spray paint. Important: Use several thin coats to achieve a smooth finish.
REPITAR
18 Mar 2021 13:28
Hello Telibe,
Regarding Malm furniture and spray paint, here is some information: You are correct that Malm furniture is usually made of particleboard with a plastic laminate or foil covering. This means the paint does not adhere as well as it would to real wood. Therefore, careful preparation is crucial.
1. Cleaning: Remove all grease and dirt residues using a degreasing cleaner.
2. Sanding: Gently roughen the surface with fine sandpaper (grit 220-320) to ensure the primer sticks. Always use light pressure to avoid damaging the laminate.
3. Primer: Use a synthetic resin or adhesion primer specially designed for smooth, painted, or coated surfaces.
4. Spray paint: Apply the paint in several thin layers, allowing each to dry thoroughly. A two-component (2K) paint or a high-quality acrylic paint works best.
5. Sealing: If desired, apply a clear sealant to increase scratch resistance.
A common mistake is neglecting preparation. Without sanding or priming, the paint hardly sticks and will peel off soon. Spray paint works well if you carefully follow these steps.
If you like, I can also provide tips on choosing the right products.
Telibe
18 Mar 2021 13:45
REPITAR schrieb:
You are correct that Malm is usually made from particleboard covered with a plastic foil. This means that paint does not adhere as well as it does on real wood.
That clears up a lot, thanks. What about the primer color options? Does it always need to match the paint color?
Mufato schrieb:
Several thin coats to achieve a smooth finish.
How long should I wait between coats? Is normal air drying sufficient, or is there anything specific I should pay attention to?
I want to avoid the paint drying unevenly or developing bubbles later on.
U
usbla
19 Mar 2021 09:33
Regarding the choice of primer color: it does not need to match the final paint color exactly, but it is advisable to use a neutral primer, such as white or gray, which allows for uniform tones and improves coverage.
The drying time depends on the paint manufacturer's instructions. Generally, 15–30 minutes between spray paint layers is sufficient when the surface is dry but still slightly tacky. It is important to work at around 20 degrees Celsius (68°F) room temperature with good ventilation to prevent blistering.
Another tip: avoid applying excessively thick coats, as too much paint in one layer can cause bubbles to form more quickly. It is better to apply several thin layers with some waiting time in between.
Domau0
19 Mar 2021 19:51
Hello Telibe,
I would like to explain the process in more detail, especially since there are some important points to consider when working with laminated furniture like Malm.
First, you should check whether the furniture is coated with paper or plastic foil – paint adhesion tends to be more challenging on plastic foil.
The first step is thorough cleaning. After that, lightly sand the surface with very fine sandpaper or sanding fleece (grit 320 or finer). The goal here is just to roughen the surface slightly, not to remove the foil.
Next, a special adhesion primer designed for plastics and smooth surfaces is required. Make sure the primer is compatible with the spray paint you plan to use – for example, acrylic on acrylic or 2K (two-component) on 2K.
The spray paint should be applied in thin layers in a dust-free environment, following the equipment instructions, allowing each layer to cure according to the manufacturer’s recommended time. This is particularly important with IKEA furniture, as improper application can cause cracks or bubbles.
Finally, a clear coat can be applied for additional durability and protection.
In summary: yes, you can repaint Malm furniture, but it requires patience, the right materials, and careful preparation. Otherwise, you risk weakening the furniture and ending up with unsatisfactory results.
What is your timeline? Do you already have specific products in mind?
