minadrian11 Mar 2018 09:13Hello everyone, I have a question: I am considering combining furniture from the IKEA PLATSA system with pieces from other manufacturers. I am particularly interested in whether it makes sense functionally and visually to connect PLATSA units with commonly available standard shelves or sideboards.
Specifically, I would like to know if the dimensions and quality of PLATSA are compatible with other furniture, and if there are any recommendations on how to proceed in order to achieve a cohesive overall look. Are there any known pitfalls or practical tips for combining PLATSA with non-IKEA furniture?
The question of whether IKEA PLATSA can be combined with other furniture can generally be answered with yes, but it requires a nuanced approach. PLATSA is designed as a modular system and has specific dimensions (typically 60 cm (24 inches) wide, 35 cm (14 inches) deep, but this varies depending on the element). When combining it with other furniture, you should consider the following points:
- Dimension compatibility: Other furniture should ideally have similar depths and heights to ensure a harmonious appearance.
- Material and surface: PLATSA uses melamine-coated particleboard, and the surface finish may not always match those of other manufacturers.
- Functionality: Attachment and stability can be compromised if elements are loosely combined.
In practice, I recommend either choosing furniture with a similar depth and design or deliberately styling the furniture group as a mix, for example by using color accents or intentionally different materials.
I can share from personal experience that PLATSA furniture can be combined quite well with other pieces if you pay attention to a few details. It is important to compare the dimensions carefully, especially the depth and height of the furniture items. When the dimensions are similar, the combinations look harmonious.
Another helpful tip is to work with color details. I have combined PLATSA in white with cabinets that have a white lacquered finish. The materials match well, even though the furniture comes from different manufacturers.
Additionally, I would recommend securely fastening each piece of furniture, for example, anchoring shelves to the wall to ensure stability.
bufukin schrieb:
When combining with other furniture, you should consider the following points:
- Size compatibility: Other furniture should ideally have similar depths and heights to ensure a harmonious appearance.This size compatibility is indeed a key aspect. I believe it is not enough to only look at the dimensions; the construction methods and assembly techniques should also be questioned. For example, PLATSA uses a sophisticated plug-in system that allows individual modules to be connected very flexibly. Other furniture often has fixed joints or uses different plug-in or screw systems.
Therefore, the question arises: is it even practical to mechanically connect PLATSA elements with other furniture, or should the combination rather be made visually and in terms of space design, without fastening the furniture together?
I would also like to see examples from users who have tried this.
To answer the question precisely: PLATSA is characterized by its flexible construction, but the system is not designed for compatible connections with other manufacturers.
From a technical perspective, the following points should be considered:
- The standard depth of PLATSA units is 35 cm (14 inches), while other furniture is often deeper (e.g., 40 cm (16 inches) or 45 cm (18 inches)), which affects floor space and arrangement.
- Attachment points and materials differ, so mechanical connections require suitable adapters or custom solutions.
- In terms of quality, PLATSA falls into the budget to mid-range furniture category, which can result in noticeable differences in material appearance when combined with higher-end furniture.
My advice: For a meaningful combination, prioritize visual coherence and only consider technical connections if the space and usage truly demand it.
MATHIASDO12 Mar 2018 10:46janeo schrieb:
Is it even practical to mechanically connect PLATSA components with other furniture, or is it better to combine them visually and in terms of room layout without screwing the pieces together?I approach it by treating PLATSA as a standalone solution due to its modular design, which can be visually complemented with other furniture.
Mechanical connections between furniture from different manufacturers are rarely practical because the systems are not compatible. For example, if you want to attach PLATSA to a wooden piece or a metal shelving unit, you would need a custom adapter solution. This is often complex and usually not stable enough.
Therefore, I recommend focusing more on color, finish, and room arrangement, and if necessary, simply placing the furniture pieces next to each other without fastening them.
