ᐅ What is the best way to transport IKEA PLATSA furniture?
Created on: 17 Apr 2021 08:46
noblake
noblake
17 Apr 2021 08:46
Hello everyone, I am planning to transport some IKEA Platsa furniture soon and am wondering about the best way to do this safely and efficiently.
Since PLATSA is a modular system consisting of relatively large and sometimes fragile individual parts, it is important to me to avoid damage during transport. Additionally, ease of handling when loading and unloading is a factor, as I will be managing the transport without professional help.
Does anyone have experience or tips on the best way to transport PLATSA? Is it better to transport the furniture fully assembled, or does it make sense to disassemble it on site after unloading? Are there any specific methods for protecting the parts, or packaging tips that have proven effective? I look forward to your recommendations and practical advice!
Kinbu
17 Apr 2021 09:12
Hello noblake, I’m happy to help! For IKEA PLATSA furniture, I generally recommend transporting the modules as flat as possible. This means that if you haven’t assembled the furniture yet, don’t screw the individual parts together—instead, transport them as flat components or partially assembled modules. This reduces the risk of damage.
If the furniture is already assembled, you should handle the joints very carefully. It’s always important to use soft padding during transport, such as blankets or foam. Also, make sure nothing can shift around—straps are useful to secure the parts in place.
One more thing: if you have a suitable van or truck, it’s better to transport large pieces lying down to avoid pressure marks. This can be challenging with smaller cars because the parts are often long and bulky.
Is there something more specific, like a particular PLATSA module, that you want to transport?
Surela
17 Apr 2021 12:38
Hello noblake, I’m happy to provide you with a detailed guide on how to safely transport PLATSA furniture.
First, consider whether the furniture can be disassembled or not. The PLATSA design consists of several elements such as side panels, shelves, back panels, and doors.
If possible, you should disassemble the furniture into individual parts:
- Unscrew connections and transport the components separately
- Remove the back panel, as it is often made of thin material and can be easily damaged
A challenge during transport is dealing with the usually disassembled large parts, which are long and relatively cumbersome. It is best to store the components flat. Recommended steps include:
- Protect edges and surfaces with blankets or thick cardboard for cushioning
- Use straps or strong hook-and-loop fasteners to keep everything together
- Also, remember to securely pack and label small parts (screws, dowels) in separate bags
If you need to transport the furniture fully assembled, it is important to secure the joints again and possibly tighten some screws to increase stability. Use soft padding between the furniture and the vehicle floor.
What kind of vehicle will you be using? This significantly affects your options. Small cars often have limited space for long parts.
I’ll ask again about your transport capacity and available tools, so I can tailor my advice more precisely if needed.
ladali
17 Apr 2021 14:04
Regarding the question of the best way to transport IKEA PLATSA furniture: the previously mentioned point about disassembling is crucial.
PLATSA modular furniture is designed for modularity, therefore:
- Prepare for transport by fully or partially disassembling
- Disassemble especially large or bulky components
- Protect individual parts with suitable packaging (e.g., bubble wrap, sturdy boxes)
Both protection against mechanical damage and efficient use of the available cargo space are the main priorities. Minimizing the risk of scratches and broken edges is paramount.
A solid organization of the load is advisable:
- Heavy parts first, placed at the bottom
- Light and delicate items on top, securely fastened
These are the basic considerations. The specific implementation depends on the situation—type of vehicle, number of helpers, and whether on-site assembly is planned.
RonJarrett
17 Apr 2021 16:27
For clarification: The PLATSA furniture series from IKEA consists of carton-packed individual parts and partially pre-assembled modules, allowing for different handling options during transport.
Important for safe transportation:
- Avoiding point loads on sensitive surfaces such as melamine coating
- Using padded supports to distribute pressure
- Securing the load with straps or tie-downs to prevent movement
When transporting in a car, there is a high risk of parts being damaged if they are tilted or hit edges. A van with a flat loading area is ideal.
My tip:
- If you want to save time and avoid disassembly, make sure to firmly secure individual parts
- Prevent as much movement of the furniture as possible
Additionally, if parts have been disassembled, collect screws and small components in a labeled location to avoid complications during reassembly.
INGRID34
17 Apr 2021 18:45
It is best to fully disassemble the furniture parts.
Protect edges with blankets.
Collect all screws in separate bags.
Straps are very useful for securing.
Transport flat, not upright.
