ᐅ Build Your Own IKEA Metod Kitchen Island with Seating Area for Optimal Use
Created on: 1 May 2020 08:34
liadaHello everyone, I am planning to extend my IKEA Metod kitchen with a kitchen island that includes integrated seating, and I want to build it myself. I am looking for the best way to design the island to make efficient use of the available space, incorporate practical storage options, and at the same time create a cozy seating area for 2-3 people. It’s important to me that the construction is stable but not too heavy, ideally using standard IKEA METOD units, while also providing enough legroom on the seating side. Do you have any experience with DIY projects like this or specific tips for planning and execution, especially regarding structural stability, storage surfaces, and seating comfort? Looking forward to your input!
Hello liada,
your project sounds great, and I’m happy to help with a structured approach so you can create a sturdy IKEA Metod kitchen island with seating. Here are some key steps and tips:
- Planning: First, determine the room dimensions and how much space you can allocate for legroom on the seating side (at least 60 cm (24 inches) clearance is recommended).
- Module selection: Use IKEA Metod base cabinets as your foundation, preferably 60 cm (24 inches) deep with varying widths to flexibly combine storage and workspace.
- Worktop: Make sure the countertop is at least 3 cm (1 inch) thick – this provides stability and a comfortable feel.
- Seating area: For seats at the kitchen island, I recommend a countertop overhang of at least 30 cm (12 inches) depth, leaving legroom underneath.
- Structural support: Secure the cabinets firmly with brackets and consider installing a sturdy back panel to add extra stability.
- Layout: You can create storage space on the backside while keeping the front side, where people sit, open.
Common mistakes include insufficient legroom, countertops that are too thin for seating areas, or neglecting connection brackets, which can cause wobbling. If you want, I can also provide more details on material recommendations or tool tips.
Best regards!
Best regards!
In addition to the points mentioned so far, I would like to go into more detail regarding the structural stability and precise assembly, as this is often underestimated:
1. Connecting the modules: IKEA Metod base cabinets are normally designed for wall mounting and require additional reinforcements to ensure secure stability, especially for islands. It is recommended to install stabilizing metal brackets inside the cabinets and add a continuous back panel made of OSB or plywood.
2. Load distribution of the countertop: For an overhanging seating area, it is important to support the countertop either with special brackets or additional legs. Otherwise, you risk bending or tipping, particularly if the countertop is made of solid wood or thick laminate.
3. Height adjustment: The seating height should be approximately 75 to 78 cm (29.5 to 30.7 inches) with standard stools to allow comfortable seating. Keep in mind that IKEA Metod cabinets are about 80 cm (31.5 inches) high, and the seating height will vary depending on the thickness of the countertop.
4. Storage concepts: I recommend including open shelving units or drawer cabinets with integrated cutlery trays in your design. This way, you can make optimal and accessible use of storage space.
I would be interested to know the exact size of the room and whether you already have specific ideas about color schemes or material choices. The floor condition can also be relevant if you want the island to be movable or fixed.
If you like, I can prepare a step-by-step guide including a material list for you.
PLOMA schrieb:
I’m curious about the exact size of the room and whether you already have specific ideas regarding color schemes or material choices? The type of flooring can also be relevant if you want the island to be movable or fixed.That’s a good question, thanks! The room is about 4.5 m (15 feet) wide and 3.8 m (12.5 feet) long, and the existing kitchen unit takes up around 2.8 m (9 feet), leaving approximately 2 m (6.5 feet) in width for the island. For colors, I’m leaning towards white cabinet fronts and a birch countertop, since the other furniture is already modern and simple. The floor is tiled, quite level and smooth. The island will be fixed to the floor to ensure it is really stable.
It’s also important for me that the seating area doesn’t block any pathways, meaning there should be enough clearance—my goal is about 1 m (3 feet) between the island and the cabinets.
Does anyone have tips on how to integrate the seating spots through positioning—so, rather on the long side or the short end of the island? Also, suggestions on which furniture modules work best for this?
liada schrieb:
Does anyone have tips on how to best integrate seating by positioning it—should it be along the long side or the narrow end of the island?From an ergonomic perspective, it makes sense to place the seating along the long side of the island. This allows for sufficient legroom with 60 cm (24 inches) cabinet depth and about 30–35 cm (12–14 inches) countertop overhang. At the same time, the narrow end remains available for storage or as a work surface.
Additionally, seating along the long side makes it easier to move around the kitchen and reduces pathway blockages, especially if at least 1 meter (39 inches) of walking space is desired.
I recommend keeping the seating area free of base cabinets as much as possible—if cabinets are necessary, open shelving is preferable to maintain a light and open feel. Also, bar stools with a seat height compatible with your countertop height are advisable.
Summary:
- Arrange seating along the long side
- Minimum 60 cm (24 inches) legroom
- 30–35 cm (12–14 inches) countertop overhang
- Clear walking paths at least 1 m (39 inches) wide
