ᐅ How do I build an IKEA Metod kitchen island with storage?
Created on: 7 Oct 2022 08:13
tarjohnnie
tarjohnnie
7 Oct 2022 08:13
I am currently planning to build an IKEA Metod kitchen island with enough storage space for my new apartment. However, I am facing some challenges, especially regarding the right combination of cabinets and the stability of the construction. My questions are as follows:
- Which cabinet frames are best suited for an island that should serve both as a workspace and storage?
- Are there specific cover panels or trim strips recommended when placing the modules freely in the room?
- How can I secure the island as stable and durable as possible without causing permanent damage to the floor?
I would greatly appreciate any tips on efficient planning, assembly steps, and materials used. Perhaps someone here already has practical experience with the IKEA Metod kitchen island and can provide a step-by-step guide or useful advice. Thank you in advance!
Timofa
7 Oct 2022 09:21
Hello tarjohnnie,
great that you’re taking on this project! A Metod kitchen island is a really cool idea, especially when you cleverly combine it with storage. 😊
Brief answers to your questions:
- For the base cabinets, I recommend the 80cm (31.5 inches) deep units, as they provide enough space to store deep pots or large containers.
- Side panels are definitely a must for freestanding islands. IKEA offers them separately, but you can also use wood or MDF panels and paint them to match. This instantly looks much more high-end.
- Stability: I secured my island to the floor using adhesive strips and brackets, which works really well without causing major damage.
If you like, I can share some tips later on how to easily manage the assembly without getting frustrated over screws and cabinet boxes!
Nofege
7 Oct 2022 11:05
Hello tarjohnnie,
I completely understand your question and would like to offer you a structured approach to planning and assembling your Metod kitchen island.
1. Planning:
- Take measurements and plan the island so that there is at least 90 cm (35 inches) of working space all around.
- The 80 cm (31.5 inches) deep Metod base cabinets are ideal for storage; make sure to include suitable drawer fronts and internal drawers in your plan.
2. Assembly:
- Start with the sturdy base frame; if you install adjustable legs underneath, use IKEA’s height-adjustable feet to compensate for any unevenness.
- Side panels are attached with concealed connectors, creating a strong connection without visible screws.
- For the countertop, a pre-drilled version designed specifically for islands is recommended. This allows you to plan for sink or cooktop installation.
3. Tips:
- Always make sure to align the cabinet carcasses properly before assembly, using a spirit level.
- The IKEA assembly manual is helpful, but I recommend also watching online videos to see each step demonstrated.
If you like, I can compile a list of recommended modules and assembly materials for you.
faso31
7 Oct 2022 13:29
Timofa schrieb:
For the base, I recommend the 80 cm (31.5 inches) deep base cabinets, as they provide enough space to store deep pots or large storage containers.
Right from the start, I understand this recommendation, but in my opinion, it is not entirely accurate. While 80 cm (31.5 inches) depth is standard, for a kitchen island that should also have visual impact and functionality, the depth is only one aspect. It is important that the island fits into the overall kitchen and that the workflow is efficient.
Nofege schrieb:
Make sure to properly align the carcasses before installation and use a spirit level.
This is a crucial point. Especially for a freestanding piece of furniture that serves as a work surface for cooking or dining, even a slight misalignment can cause problems later—ranging from instability to misaligned doors. I would also recommend stabilizing the island by securely connecting the individual modules with screwed fasteners.
I’m curious to learn how others address stability without firmly anchoring the island to the floor, as this seems critical to me.
tarjohnnie
7 Oct 2022 14:47
Thank you very much in advance for your detailed responses!
Regarding stability, I find the suggestion that the individual modules should be connected to each other very interesting – so far, I had only considered securing them to the wall, which is not always possible with an island.
So, could the modules be joined together into a single unit using sturdy brackets and connector plates? Does anyone have experience with whether such an island can be moved easily without causing damage?
Also, I am wondering how to fix the countertop. IKEA offers mounting kits or special screws. Is it worth using those for a kitchen island, or would adhesive be a better option?
kemeo68
7 Oct 2022 17:02
tarjohnnie schrieb:
So, could you connect the modules using sturdy brackets and connector plates to create a single unit?
Of course, you could! But why take these detours in the first place? The Metod series is actually designed for wall mounting, so it’s no surprise you’re running into issues here. The question is: Do you want “just” storage, or do you really want an island that functions as a work surface?
I often see people sticking to the IKEA concept and then trying to force the whole system into an open-plan space. I would rather go for a custom-built base or reinforce the island with a solid substructure made of a timber frame, instead of just cobbling everything together with metal brackets.
Stability doesn’t come from more screws, but from suitable materials and good construction. Unfortunately, IKEA doesn’t operate that way—they only offer their standard components.
Just my provocative opinion—but one that often proves true.
