Created on: 27 May 2019 10:48
goalkeeper
kaho67425 Aug 2019 10:22
goalkeeper schrieb:
After our general contractor consulted with the geotechnical engineer, it seems a solution using reinforced L-shaped concrete blocks along with backfilling is possible. After that, the geotechnical engineer will carry out the inspection and load plate bearing tests.
Sounds complicated. If the load plate bearing tests indicate the site is "unsuitable for construction," what happens then?
You could ask your bargain neighbor if they’d also build you a basement.
goalkeeper
25 Aug 2019 10:24
kaho674 schrieb:
Sounds complicated. If the bearing plate load tests show the site is "unbuildable," what happens then?
They are only done for the filled area. If that doesn’t meet the requirements, the site supervisor has to make corrections.
The actual ground is suitable for construction without any issues.
kaho67425 Aug 2019 10:26
goalkeeper schrieb:
They are only made for the filled-in part.
I thought you have to fill in all the areas where you want to build, including parking spaces?
goalkeeper
25 Aug 2019 10:33
kaho674 schrieb:
I thought you have to backfill everywhere you want to build, including parking spaces?
Exactly – and the earthworks contractor carries out this backfilling – so they also need to ensure that the compaction tests meet the requirements.
goalkeeper
26 Aug 2019 17:36
So... the quotes are in: Backfilling is around 15,000, the basement around 50,000. The savings from a crawl space basement are too small to be noticeable. We will therefore choose the backfilling option.
HilfeHilfe
26 Aug 2019 17:39
goalkeeper schrieb:
So... the quotes are in: backfilling costs 15,000, the basement is 50,000. The savings with the crawl space basement are too small to make a real difference. So we will decide to go with the backfilling.
Annoying!!
