ᐅ BILLY Shelf DIY Painting – Tips for Home Improvement Enthusiasts
Created on: 19 Jan 2016 13:47
klogiHello everyone, I am currently planning to paint a BILLY shelf from IKEA myself, as I am not satisfied with the standard color. My specific question is: What preparation steps are truly necessary when painting a BILLY shelf made of wood-based material to achieve an even, durable, and attractive finish? Are there particular primers, sanding methods, or special types of paint that are especially recommended? I have done some research and read that the wood-based material needs to be treated somewhat differently than solid wood, but practical tips based on personal experience would be very helpful. Thanks in advance!
Hello klogi, generally I recommend the following approach for a BILLY shelf made of wood-based panels: First, completely disassemble the shelf and lightly sand all surfaces with 220-grit sandpaper. This ensures good adhesion of the paint. Then, use a special primer designed for wood-based panels, as it seals the material and evens out any irregularities. It is important to use a primer specifically formulated for particleboard or MDF, since regular wood primers may not always adhere well here.
After the primer has dried, sand lightly again (e.g., with 320-grit) to ensure a smooth surface. For the topcoat, I recommend acrylic paint or polyurethane (PU) paint, depending on how durable you want the surface to be. Acrylic paint is easier to apply, while PU paint is more robust but also a bit more demanding. Between paint layers, you should lightly sand to avoid dust inclusions.
These steps will help achieve an even and long-lasting finish. Of course, the application method (spray gun, roller, brush) also plays a role, but with a good primer and the right paint, you are already well prepared.
NoValentin19 Jan 2016 15:03Sand the shelf, prime it with MDF filler or a wood-based primer, sand again after drying, then apply the paint, preferably in several thin layers. Acrylic paint is well suited.
GLORIA schrieb:
For painting, I recommend acrylic lacquer or PU lacquer, depending on how durable the surface needs to be.I would add here that while PU lacquer is more robust, it’s not ideal for every DIY enthusiast because its handling (smell, drying time, application steps) is considerably more demanding. So: if someone has experience with lacquers, PU lacquer is definitely a good choice; for beginners, it might cause more frustration.
Also, the benefits of the appropriate sanding methods should not be overlooked. Especially the intermediate sanding with fine sandpaper after priming is essential and greatly affects the final finish.
I’m also wondering: has anyone had specific experience with the surface temperature during painting on BILLY shelves? Since it’s a wood-based panel material, it could react to overly hot conditions and cause blistering. Concrete information about the climate or temperature in the painting environment would be very welcome here.
And one more often overlooked point: the type of primer. Sometimes it’s better to use a solvent-based primer if the wood-based panel is especially porous.
