ᐅ How can I enhance the color of BILLY shelves without damaging them?
Created on: 24 Mar 2021 08:17
Claude
Hello everyone, I have a few Billy shelves from IKEA at home and would like to enhance their appearance with color to better match my living room. It is important to me that the shelves are not damaged in the process, as I might want to use them again in their original condition or sell them later. Does anyone have tips or proven methods for changing the surface color of the shelves without affecting their stability or the material underneath? I am thinking of options like special stickers, films, spray paint, or other creative solutions that would leave no residue. I appreciate any ideas or experiences!
Dirkmin
24 Mar 2021 11:45
A main challenge when upgrading the color of Billy shelves is their melamine-coated surface. This material is sensitive to abrasive methods.
When using paint, I recommend chalk or acrylic paints specifically designed for veneered or melamine-coated surfaces. These provide good adhesion and can usually be removed cleanly with acrylic-based solvents without damaging the underlying material.
Before applying spray paint, it is advisable to lightly sand the surface with fine sandpaper (grit 400 or finer) to improve adhesion. Sanding should be done carefully to avoid damaging the substrate.
Films are a gentler alternative; however, it is important to pay attention to the quality and adhesive side because some low-quality films can leave residues when removed.
Claude
24 Mar 2021 12:25
Thanks, Dirkmin, that was exactly my concern. How easily can the surface actually be damaged? Do you have experience with how thoroughly one needs to sand without breaking through the melamine coating? And what about residue-free removal, in case everything needs to be taken off again?
taudi
24 Mar 2021 12:52
Claude schrieb:
How easily is the surface actually damaged?
The melamine-coated surface is thin and very delicate; using sandpaper that is too coarse quickly causes loss of gloss and visible scratches.
I recommend using only very fine sandpaper (at least grit 400 to 600) and sanding very lightly—this is sufficient to improve adhesion.
For removing paints: acrylic paints can often be dissolved with special paint remover or isopropyl alcohol, but they may leave marks if the surface has been damaged.
In summary: if you want to avoid residue, stick to films or removable furniture veneers.
Aimee
24 Mar 2021 13:33
Another quick option is contact paper. It comes in many colors and patterns, is easy to cut, and can be removed without leaving any residue. It works well for BILLY shelves if you don’t want a permanent change.
piflo
24 Mar 2021 16:07
I completely understand that you don’t want to damage the shelves. For me, it’s more important to prevent any permanent damage from possible trial and error. That’s why I chose to use films. They look great but also give me peace of mind in case I want to rearrange things later. 🙂
Would it also be an option for you to enhance the shelves with fabric or textile coverings? I think that adds a lot of color and is relatively gentle on the surfaces.
Claude
25 Mar 2021 09:14
piflo schrieb:
Would it also be an option for you to enhance the shelves with fabric or textile covering?
That sounds interesting. Have you tried that yourself? I’m wondering how to attach it without damaging the shelf. Tape or staples wouldn’t be an option for me. Are there any special methods or materials that can be used? And is it a complicated process?
