ᐅ Reducing Creaking Noises in BILLY Shelving Units – Effective Methods
Created on: 11 Feb 2020 08:23
DobauHello everyone,
I have an IKEA BILLY bookcase that unfortunately creaks or squeaks with almost any movement. It’s especially annoying when I pull something out or lightly touch the shelf – the noises are quite unpleasant and make an otherwise very practical storage solution less enjoyable.
My question to the community: What are effective methods to permanently reduce or completely prevent these creaking sounds on the BILLY bookcase?
I’m particularly interested in practical and easy-to-apply tips that DIY enthusiasts can use without much effort or special tools.
For context: I’m aware that the issue often comes from the friction between the shelves and the side panels or the attachment points. But I’m unsure whether lubricants, greases, or cushioning materials work best, and how to apply them correctly without damaging the bookcase.
Looking forward to your advice!
Hello Dobau,
I am familiar with the issue of creaking noises in the BILLY shelf, and I’d like to provide you with a clear, structured overview of how to address the problem.
1. Identify the cause: It is usually due to friction between the shelf supports and the side panels, or slightly loose joints.
2. Cleaning: Before applying anything, make sure to thoroughly clean all contact points. Dust, dirt, and any old residues often worsen the noise.
3. Lubricants: For furniture, I recommend silicone or Teflon sprays. These are safe for plastic and provide good protection. Use them sparingly and only on the load-bearing surfaces of the shelves or the support points of the shelf brackets.
4. Felt or foam rubber strips: A very effective method is to insert thin felt or foam rubber between the shelf and the side panel. This prevents direct friction and significantly reduces noise.
5. Profiled adhesive tape: Special furniture or felt tape can be applied to the edges of the shelves to cushion the contact surface.
6. Check screws: Also check all screws for tightness. Loose connections can also cause creaking sounds.
7. Check assembly: An unstable assembly can promote these noises due to movement. Adjust if necessary.
In summary: Clean → Apply lubricant (silicone, Teflon) sparingly → Use felt/foam rubber pads in between → Check screws and assembly.
Hope this helps. If you need more detailed advice on the application, just let me know!
Here are a few additional facts and suggestions:
- Creaking noises on the BILLY shelf often result from wood-on-wood contact, which intensifies due to temperature and humidity fluctuations.
- Silicone spray is the best option because it does not become sticky and therefore does not attract dirt. WD-40 or other oil-based lubricants can become sticky over time and may cause more damage.
- Alternatively, low-friction materials such as felt pads or special plastic furniture glides can be used. These should be cut precisely to prevent slipping.
- A slight amount of movement in the shelf should be allowed, as overly rigid fastenings can create gaps that promote creaking.
- Installing the shelf on non-slip pads (e.g., rubber pads on the shelf feet) can help reduce vibrations.
My recommendation: First, apply felt or foam rubber strips at the contact points, then use silicone spray sparingly in targeted areas only.
giabau schrieb:
Felt or foam rubber strips: An excellent method is to place thin felt or foam rubber between the shelf and the side panel. This prevents direct friction and significantly reduces noise.That sounds interesting, thanks! What thickness should these strips have so they don’t add too much bulk but still dampen noise effectively?
Also, do you have to glue the felt in place, or is it enough to just lay it in loosely? I’d prefer not to glue anything in case I want to use the shelf differently later.
Additionally, I wonder if the shelf might lose stability by adding, for example, thicker strips.
What are your experiences with this?
Hello Dobau,
Regarding your questions:
1. Thickness of felt or foam rubber strips: Ideally between 1 and 2 mm (0.04 and 0.08 inches). This is usually enough to prevent direct contact without compromising stability.
2. Glued or loose: Gluing is generally better because a fixed position ensures the pads don’t shift. However, you can also use double-sided tape that can be removed without leaving residue. Loose placement is possible, but the felt may move or slip during use.
3. Stability: The slight cushioning from thin materials hardly affects stability, as the load from the shelf board still rests firmly on the supports and side panels.
If you want to be on the safe side, I recommend tape with a thin layer of felt – this is practically the standard.
Good luck!
Good luck!
