ᐅ What should you do if BILLY shelves make rattling noises when moved?
Created on: 20 Aug 2024 08:34
Giroju
I have several IKEA Billy bookcases at home that I move around quite often, for example when cleaning or reorganizing. However, I noticed that the shelves make an annoying rattling noise when moved, which is quite bothersome. The noise probably comes from the connections or possibly from the locking of the shelves.
My questions are:
- What can be done specifically to avoid or reduce the rattling noise?
- Do the shelves need to be reassembled, different fasteners used, or are there any special tricks?
- Is this a known issue with Billy bookcases, and are there any replacement parts that might help?
I would appreciate concrete suggestions and any experiences with this noise issue. Thank you!
tra_nina
20 Aug 2024 10:22
Regarding rattling in Billy-style shelves, I have a structured approach:
- First, remove all shelves and check the support pins for deformation or dirt.
- Then, inspect all screws and connections, tightening them if necessary.
- For larger fitting inaccuracies, roughening the dowel holes with sandpaper can help the glue bond better.
- Felt or rubber pads placed between the shelf and side panel effectively dampen vibrations.
This method has proven to be a best practice and is cost-effective.
Domau0
20 Aug 2024 10:49
A few technical details on this topic:
The BILLY shelf uses MDF-coated particleboard that can slightly flex when moved if the fasteners are not fitted precisely. The rattling noise usually comes from the contact points between the shelf supports and the drilled holes in the boards.
My recommendation:
1. Remove all shelves and thoroughly clean both the pins and the holes (remove dust and wood chips).
2. Check all dowels for wear – reusing them is only advisable if they fit firmly.
3. To reduce rattling, you can apply a thin layer of white wood glue lightly into the dowel holes. This fills small gaps caused by minimal tolerances.
4. Allow the necessary drying time before reassembling.
5. Additionally, I recommend double-sided tape or thin strips of foam rubber as bump stops on the dowel heads to dampen noise.
It is also important to carefully check the shelf alignment (whether the side panels are parallel), as misalignment encourages movement.
Can you say whether the rattling occurs equally on all levels or only in certain areas?
Giroju
20 Aug 2024 11:13
Domau0 schrieb:
Can you say whether the rattling occurs equally on all shelves or only in certain areas?
Good question, thanks! The noise is actually strongest on the lower shelves, especially the one near the bottom. The upper shelves make hardly any noise. The shelves stand on a smooth laminate floor, so maybe that plays a role?
To clarify: the rattling only happens when the shelves are being moved as a whole, not when just taking something in or out. I therefore suspect it has to do with the entire unit shifting and the connections not always being firm.
Kinbu
20 Aug 2024 11:28
This is an important note and directly relates to a common issue: the lower shelves and their contact points often bear the most stress when there is movement, especially if the shelf unit slightly rubs against the floor or wobbles over a small uneven spot.
My advice: Check if there are small irregularities under the shelf feet or if the unit is not sitting completely flat on the laminate flooring. Even a slight tilt or wobble, however minimal, can increase noise.
Rubber pads on the feet or small felt furniture glides can help reduce friction on the laminate, thus minimizing rattling sounds.
Additionally, I would make sure the shelf unit is perfectly level. A spirit level can be useful for this.
Giroju
20 Aug 2024 11:46
Kinbu schrieb:
A slight tilt or wobble, even minimal, is enough to cause the noises.
That fits well—I actually have a slight slope in the room, and on one side the shelf stands a bit wobbly.
What would be the most effective solution in such a case? Adjustable feet are not standard for BILLY, right? I like the idea of felt pads, but are they enough if the shelf really isn’t perfectly level?
Or would it be better to try using wooden shims? Are there any recommendations on the best way to do this without affecting the shelf’s appearance?
Fitigu
20 Aug 2024 12:11
To fix wobbling issues with BILLY shelves on uneven floors, adjustable feet are not included as standard; however, third-party providers may offer suitable furniture glides with threaded stems.
If you prefer a more discreet solution, thin furniture wedges made of wood or plastic are a practical alternative. You can place these under the affected side, depending on the severity of the slope.
It is important that the wedges are stable and do not slip. To ensure this, double-sided tape can be used.
Felt pads are very effective at reducing noise during movement but do not replace stabilization against wobbling.
In summary:
1. Compensate for unevenness with wedges
2. Reduce noise with felt pads
3. Check screws and connections
This effectively reduces rattling issues.
