ᐅ Billy Regal squeaks when opening – what can I do?
Created on: 25 Jun 2022 08:37
makin
I have a Billy bookshelf from IKEA that has been making quite an annoying squeaking noise when opening the doors for some time now. The sound occurs especially when the doors are not fully aligned or when I open them quickly. The hinges seem to be intact, and there is no visible rust, but the bookshelf is already several years old.
Does anyone have experience with what exactly causes this squeaking? Is it usually due to the hinge, the plastic bushings, or moisture? And most importantly: what medium- to long-term solutions are available to permanently fix the squeaking? I would prefer not to replace the hinges completely, but rather try maintenance or care first.
I would really appreciate any tips!
makin
25 Jun 2022 14:40
Thanks to everyone who has already given me such helpful assessments!
Klo40, MUMENAR, Gafiel, and warrenka57 – one thing is still unclear to me: How can I visually or by simple touch tell if the bushings are brittle or damaged? Is it worth removing the door for a closer inspection, or is there a way to check the hinges more thoroughly while they are closed?
Also: Should I definitely use silicone-based spray afterward, or is Teflon better? At the hardware store, I’m often unsure which product is best for the small plastic components in the hinges.
Deandre
25 Jun 2022 15:03
Hello makin,
a very good question!
First of all: The best way to check is actually to remove the door and have the hinges easily accessible. This way you can inspect the bushings directly for cracks or crumbling. Brittle bushings can be identified by the fact that they crumble easily or small fragments break off when you scratch them with your fingernail.
If the shelf is quite old, plastic bushings sometimes appear yellowed or dried out and feel rough.
Regarding lubrication:
- Silicone oil is very suitable because it is safe for plastic parts, does not attract dust particles, and lasts a long time.
- Teflon-based products are also good, but often have a slightly different consistency and may leave residues depending on the product.
My tip: Silicone spray, as it is easier to apply, absorbs faster, and is commonly recommended for furniture and plastics.
One more tip: After lubricating, open and close a few times to distribute the product well.
klo40
25 Jun 2022 16:57
makin schrieb:
How can I visually or by simple touch tell if the bushings are brittle?
A great additional question!
When observing the hinges while they are installed, watch for unusual play or rattling noises. Brittle bushings often have cracks that you can see or feel on the surface. It’s best to use a flashlight and a mirror to inspect the inside of the hinges without immediately removing the door.
Deandre schrieb:
Silicone spray, as it is easier to apply, absorbs faster, and is generally recommended for furniture and plastics.
I agree, glue residues in Teflon oil can cause issues, especially when dust accumulates.
Summary:
- If there are visible cracks, crumbling, or rattling: replace the bushings.
- Otherwise: lubricate and check the screws.
If you decide to replace them, keep all screws in a small container so they don’t get lost 😉
theota
25 Jun 2022 18:21
I find it interesting that there is so much talk about lubricants here – but honestly, isn’t that just a placebo effect?
klo40 schrieb:
Use a silicone-based lubricant (no oil, as oil attracts dust).
Sure, but in the end, the lubricant only replaces the natural sliding properties of the materials. If the bushings are brittle or even broken, no spray will help. In my opinion, you shouldn’t keep tinkering for too long when the shelf is already old and causing such problems – it’s better to get replacement parts or change the hinge right away.
Of course, nobody wants to take everything apart immediately, but the durability of the construction should also be considered.
Gafiel
26 Jun 2022 09:13
Regarding durability and the fundamental question of wear and tear in furniture construction for Billy shelves:
It is true that material fatigue cannot be resolved by lubrication alone. Lubrication is a temporary measure – it reduces friction and minimizes noise in properly functioning components.
The plastic bushings are often the primary wear parts because they undergo significant mechanical stress. If they become brittle, any treatment with oil or spray will at best only delay the problem.
Here is the recommended procedure:
1. Remove all hinges and inspect the bushings.
2. Replace immediately if there are any cracks or breakages.
3. Use lubricant on intact bushings.
For the replacement you will need:
- Replacement bushings (available online or in IKEA spare parts lists)
- Phillips screwdriver
If you do not have replacements available, you can temporarily treat the hinges with silicone spray and check the effect after 2-3 weeks.
I wonder, though: do you use the door heavily or is it subject to strenuous use (children, frequent opening and closing)? This would accelerate wear.
makin
26 Jun 2022 09:46
Gafiel schrieb:
If you don’t have a replacement available, you can temporarily treat the hinges with silicone spray and check the effect after 2–3 weeks.
That sounds like a good plan, thank you!
The usage is fairly normal, not extremely frequent, and there are no children slamming the doors or anything like that.
I will carefully remove the door today or tomorrow and take a look at the bushings. If they are brittle, I will order the replacement parts and then report back on how it goes.
Thanks to everyone who has helped so thoroughly – I now feel well prepared to carry out the repair! 🙂
