Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
So you use air conditioning and controlled mechanical ventilation as two separate, central systems? For me as a layperson: how is the distribution of cool air handled? Is it through a separate duct system with separate outlets similar to the controlled mechanical ventilation? Or do you use split units (which I don’t think is the case)?
Okay, thanks. So, figuratively speaking, this means that the mechanical ventilation system and the air conditioning unit share the ductwork, and you either use the mechanical ventilation system or the air conditioning unit, which means the air conditioning component can be retrofitted. Did I understand that correctly?
Not exactly
The ventilation unit always distributes the air.
When passive cooling is used, the air is drawn in through the ground, passed through the bypass (meaning it does not go through the heat exchanger), and blown into the house. During active cooling, the cooling unit also operates, and the air likewise flows through the bypass.
For pure ventilation function, the air passes through the heat exchanger.
So, there is a duct system, a large ventilation unit, and a large air conditioning unit.
Steffen807 Jul 2019 20:57It only has disadvantages for me. Why not use a separate air conditioning system that efficiently cools the air only in the specific room?
