Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick20188 Jul 2019 09:44
@sichtbeton82 Thanks for the compliments, but it won’t be that grand or special. I’ve seen other houses like that.
I also hope it won’t be shown anywhere. We are building it for ourselves, not for others.
Here I’m only sharing parts because I have benefited from this forum as well.
I have no ambition for my house to appear in magazines like Schöner Wohnen or similar.
I just visited the architect and finalized the facade design.
It will be matte concrete-look Alubond panels. Now, only the facade layout needs to be adjusted to the panel size.
rick20188 Jul 2019 09:48
haydee schrieb:
Can you adjust the airflow rate using software, or is it set manually with valves and then only controlled via fan speed levels?
In some areas, we can influence the airflow rate through electrically controlled valves in the ducts.
Manually at the inlet and outlet valves.
The fan speed levels change the overall volume flow but not the ratio between the individual areas.
haydee
8 Jul 2019 09:54
Yes, only in a standard single-family house can you adjust the fan speeds; the rest must be manually set on the valves, and a layperson should avoid touching them.
rick20188 Jul 2019 10:03
Otherwise, the balance between supply and exhaust air will no longer be correct, especially in areas with airflow between rooms.
For example, if I have 3 supply and 3 exhaust vents in the equipment room, I can close 2 of each, and the ratio will still be correct because it doesn’t need to be balanced with other areas.
In practice, you will spend some time testing to find the right setting, program different scenarios, and then only retrieve the settings as needed. The valves in the ducts should be sufficient to achieve the desired variations in air volume.
haydee
8 Jul 2019 10:05
The regulation would theoretically fit well with our ventilation and heating concept. However, it would likely cost a five-figure sum for just a bit more comfort.
rick20188 Jul 2019 10:09
Because of the significantly larger ventilation unit, additional ductwork, valves, and the cooling system, the costs are likely to be in the six-figure range even for smaller houses. The control system does not require much extra effort since a BUS system with a logic controller is already in place.
