Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
Steffen80
7 Jul 2019 22:29
rick2018 schrieb:
Because we wanted it cool everywhere. For a building this size, a central system also makes more sense.
Same temperature in the bathroom and bedroom? In summer, we keep the bedroom constantly at 22°C (72°F), while the bathroom is usually over 25°C (77°F). The living room is 23–24°C (73–75°F), and the office is also 23°C (73°F). There is a lot of heat generated there (computers, 6 monitors, etc.). It needs significantly more cooling capacity than the rest. Sorry, but I still only see disadvantages in your solution. Mechanical ventilation with heat recovery is for fresh air, while air conditioning/heating is for cooling and heating. To me, these systems should be separate.
rick20187 Jul 2019 22:39
Different cooling capacities are ensured by varying the air exchange rates. This also allows for different temperatures. For the size of our house, this is the most practical solution, although there are always several options that can achieve the desired result.
Steffen80
7 Jul 2019 23:26
rick2018 schrieb:
Different cooling capacities are ensured by varying the air exchange rates. This also allows for different temperatures. For our house size, this is the most practical solution, although there are always several solutions that can achieve the desired result.
Can you adjust the airflow volume per room? I would really like that... unfortunately, none of the known manufacturers of controlled residential ventilation systems (single-family homes) have offered this.
rick20188 Jul 2019 07:00
This is something we can do (within certain limits). It is absolutely uncommon in single-family houses. In such houses, you usually have a relatively small ventilation unit, rooms where air is extracted, and rooms where air is supplied. The rest is balanced by airflow through door gaps. That is the draft you feel at your doors.
To achieve different airflow rates, you need a significantly larger ventilation unit, much more ductwork, valves...
But most importantly, separate supply and exhaust air in all areas. Few to no zones balanced by airflow through gaps.
For example, our technical room with servers (where most of the waste heat is generated) has twice as many supply and exhaust outlets as the adjacent fitness area, even though the fitness area is 2.5 times larger.
The door in between has an all-around seal, mainly for sound insulation. Since both supply and exhaust air are within the same room, no pressure differences arise with the adjacent room.
The design of the separate supply and exhaust valves determines the overall airflow rates. The volume can still be adjusted using valves in the ducts, ceiling diffusers, and the ventilation unit itself.
What is not possible is, for example, increasing the airflow in the fitness area to match that of the technical room (relative to room size). There simply are not enough supply and exhaust outlets.
Now I also understand why you were critical of the air conditioning solution. Using a “standard” heat recovery ventilation design would make little sense for several reasons.
sichtbeton82
8 Jul 2019 08:51
Incredible and huge! Wishing you continued hard-working builders! The little touches, like with the ice for example, really make a big difference. Keep it up!
I can already see the house on NTV's "The 5 Most Gigantic Single-Family Homes in Germany"
haydee
8 Jul 2019 09:43
Can you then adjust the airflow volume through a software solution, or is it manually set via valves and after that controlled only through fan speed settings?
