Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
Jenpa
6 Jul 2019 17:58
Back from the architect.
I don’t want to hijack your thread, but I find the discussion on “cooling through controlled ventilation” very interesting, as it is also a topic for us. Therefore, I would appreciate any experiences from you @rick2018 and @Steffen80. Our architect summarized the topic as follows: it is possible and works, but don’t expect miracles. More details are supposed to come from a joint appointment with a heating, ventilation, and air conditioning specialist.
guckuck2
6 Jul 2019 18:06
200 m³/h (118 ft³/min) at a ventilated volume of 1200 m³ (42,380 ft³) is low, @Steffen80.
Is there a specific reason for this?
The airflow rate is significantly below the hygienic minimum air exchange rate.
rick20186 Jul 2019 18:15
@Jenpa forget about reversible cooling through controlled ventilation systems. It only provides a small buffering effect, nothing more.
If it doesn’t cost much, include the module with the controlled ventilation, but don’t expect air conditioning.
The standard air exchange rates are far too low (0.1–0.4 per hour) to have a significant impact. The air also won’t be truly cool. To cool by air exchange, you need rates that are ten times higher than those of standard controlled ventilation systems.
The same applies to reversible heat pumps and cooling through underfloor heating systems.
Proper air conditioning only makes sense with high air exchange rates (split units, fan coils…) or via walls and/or ceilings.
rick20186 Jul 2019 18:17
guckuck2 schrieb:
200m3/h (118 cubic feet per minute) with 1200m3 (42,390 cubic feet) of ventilated volume is low, @Steffen80.
The airflow rate is well below the minimum required for proper ventilation.
Probably poor planning of supply and exhaust air, which causes drafts even at such a low air exchange rate.
Steffen80
6 Jul 2019 22:08
There are no drafts in our home, even at a maximum ventilation rate of 500 m³/h (295 cfm). We simply don’t need that much airflow. I measure VOC levels in every living space, and usually, 200 m³/h (118 cfm) is enough to keep the concentration at 500-600 ppm.
We have a separate air conditioning system that cools the entire house! I would definitely do that again. Worth every penny. If I want, I can cool the whole place down to 18°C (64°F) even without a mechanical ventilation system or cold floors.
rick20186 Jul 2019 22:49
Alright, then it fits. But if you feel drafts at the doors, they are leaking air. This can also be solved with valves in the wall.
We will also be able to properly cool the house since there is a separate air conditioning system.
