Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201820 Apr 2020 21:14
@11ant The roofer, for example, usually works only on large-scale projects. He only took on our house because he wanted to and was working on another large project with the architectural firm at the same time.
The structural builder also primarily works in project construction.
The HVAC company handles both project construction and smaller projects like single-family homes.
The design features are not that important.
I have connections in some areas, so we were able to access additional expertise.
The mechanical ventilation system with heat recovery is, for example, one of the first from the new series.
Müllerin
20 Apr 2020 22:47
rick2018 schrieb:
He thanked us for the prompt payment of the deposit invoice. Apparently, that’s not very common.
Even disregarding the current interest rate situation, we also pay immediately whenever possible (i.e., when nothing still needs to be checked first, as with the final invoice, for example). And no, this really isn’t common; unfortunately, many public authorities lead by negative example, with companies sometimes having to chase them for payment for ages.
rick201820 Apr 2020 22:48
@Müllerin For public projects, yes. But apparently also for private construction projects.
Henning_85
21 Apr 2020 01:09
rick2018 schrieb:
The mechanical ventilation system with heat recovery is, for example, one of the first models in the new series.
Which one will be installed?
rick201821 Apr 2020 05:04
@Henning_85
Our ventilation design is rather unusual for a single-family home.
The system is sized well above standard, with almost no areas of air bypass, etc.
Due to the size of the house and the concept, the ventilation unit is actually intended for large buildings.
It is a Helios air1 (XH series).
I understand that you are still in the "planning phase" of your build and also want/wanted a Bauhaus style. So just a tip: our ventilation system is not suitable as a reference.
You will need a "standard" mechanical ventilation with heat recovery (MVHR) system, such as the Helios EC series, Zehnder ComfoAir Q, or something similar.
Bookstar
21 Apr 2020 09:23
rick2018 schrieb:
@Müllerin Yes, for public projects. But apparently also for private construction works.
For some, it’s laziness, but for others, it’s about security. Once a payment is made, you rarely see a tradesperson again. You become invisible. That’s why it’s best to pay the remainder as late as possible. A lesson I learned during my construction experience. Except for tradespeople whom I know to be different.
