Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
As far as I know, nowadays glass panes are always filled with gas (not air). These are adjusted for the pressure conditions at our sea level. The glass is specially decolorized with the appropriate protection rating. So, this is not just a custom fabrication in terms of size. Of course, the entire glass unit (insulated glazing unit) with multiple panes is replaced. Only the pane itself sits in the rear glazing bead. Therefore, the front, sliding element must also be removed for the replacement.
@guckuck2 show your windows
rick2018 schrieb:
Only the pane is positioned in the rear track. Therefore, the front and movable element must also be removed for replacement.Ah, I see! I was confused about the front/rear panes. I didn’t realize that two panes are located on two separate levels, one in front of the other.
rick2018 schrieb:
These are compensated for the pressure differences at our sea-level altitude.Isn’t transport interesting when passing through significantly different elevations?
rick2018 schrieb:
@guckuck2, show us your windowsThere are no photos of my place online
They would be pretty boring compared to your glass anyway
rick2018 schrieb:
How large is your glass area?I’m not sure I gave the impression of having a particularly upscale property… 200 sqm (2150 sq ft) white cube with some technical features, plastic windows, as well as wood and exposed concrete accents.
The glass area is in the living room: 3 x 2 m (10 x 6.5 ft) facing south, combined with an additional 4 m (13 ft) corner section to the west (lift-and-slide door).
One could arrogantly say “10 meters!” but that would only be half true.
@tumaa what do you mean by nice?
I try to follow general rules of conduct and decency. I expect the same from others. Sometimes a little kindness is also appreciated.
Good work should be acknowledged as well.
But I’m definitely not “easy” to deal with, at least that’s what my wife says.
Sorry Tumaa, we are not running a guesthouse.
Our home (like anyone else’s) is something very private.
That means only family and close friends will enter. Acquaintances are out of the question.
As soon as the furnishing and personal items are in the house, the photo documentation will be more selective.
I’m sharing this building report because I have also benefited from the forum. Usually, such projects are kept quite private. It’s also good to see something other than the standard now and then. Maybe some of the detailed solutions will be useful for someone in the forum.
What stands out very positively is that hardly any discussions about envy have come up.
This is not about showing off for me.
I have been lucky in life but also gone through some low points. So I know what priorities matter to me. We are excited about the house but we wouldn’t be devastated if we had to stay in our current living situation.
Once the basic financial needs are covered, money should not be the top priority.
At least I’m off the hook for the “forum meetup at my place” because of Corona, which developed a momentum some time ago.
