Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
rick2018 schrieb:
As soon as the poured asphalt is finished tomorrow, work on filling the drywall joints and the painting will need to begin. I will be doing most of it myself again.Do you also spray the filler with an airless sprayer? What type of wall coating will be applied to the drywall?
Thank you!
Bookstar schrieb:
Are the costs per m2 very high? Surely 100 Euro+ or more? Do you mean net or gross, installed or just materials?
Generally, a different substructure is required. The material costs for the panels are also quite high.
There is also significant waste to achieve, for example, a continuous joint pattern, built-ins...
There are also differences in the material itself (type of wood, joint pattern, UV protection...)
Furthermore, we have quite a lot of ceiling area to cover. That increases the final total significantly.
We chose one of the less expensive materials (because we liked it).
Fully installed, the cost is well above 200€ / m2 (square meter) gross.
@HarvSpec The drywall panels are finished by professionals in the traditional way with joint compound. A white primer (StoPrim Color) is applied, followed by the paint (StoColor Sie Premium). The paint layers are the same as those used on the concrete walls that are painted.
We do not have that many areas with drywall. Many areas with concrete will remain exposed concrete.
A few minor details are not final yet (painting yes/no, up to where, etc.)
Also, not all areas will be spray-painted. We don’t need to consider the ceiling yet (as it’s not installed), but spraying only makes sense if there is a large surface area compared to the masking effort. For small rooms with extensive masking needed, rolling is preferable. Spraying requires much more thorough and stable masking.
rick2018 schrieb:
We don’t have that many areas with drywall. Many areas with concrete will remain as exposed concrete. Have you considered making the drywall look like concrete walls as well?
