ᐅ How much did you pay for your mechanical ventilation system with heat recovery?
Created on: 10 Sep 2015 19:30
Grym
I’m currently a bit uncertain about what a balanced mechanical ventilation system with heat recovery should realistically cost. Two different suppliers offered quotes for the exact same floor plan, and one came in at 8,500 EUR while the other quoted 13,000 EUR. Could it be that Supplier A forgot to include a lot of important components? What have you paid for your balanced ventilation system, and what was included—such as sufficient sound attenuators, preheating coils, ground-source heat exchangers, enthalpy exchangers, and other optional features?
A 53% price difference is quite significant.
Wolf CWL 300 with a simple heat recovery exchanger without pre-/reheating coils or any other air treatment, using Helios flat ducts integrated into the insulation of the ground floor ceiling/wall outlets and upper floor floor/wall outlets.
In total 4 exhaust air and 5 supply air outlets... 2 silencers on the unit and a condensate drain...
Approximately 7,000 including installation, however in 2011.
164 sqm (1,775 sq ft) living space
Controlled residential ventilation Helios 270 EC
2x 10-port distributors
2x heavy sound attenuators (17 kg / 37.5 lbs each)
7x supply air vents
7x exhaust air vents
150 linear meters (492 ft) round ducts
Spiral ducts and small parts
Planning and installation by owner
Cost 4500€
7x supply air vents
Cost 4500€
130 m² (1400 sq ft) living area
Controlled residential ventilation Paul Novus 300
Ground heat exchanger InovaTech Inno SLD301
Distribution through spiral ducting into 5 supply air and 4 exhaust air rooms
A silencer after each valve plus 4 unit silencers
Planning and commissioning according to the ground heat exchanger
Installation by owner
Cost 8500€
Cost 8500€
Bieber081517 Dec 2015 13:48157 m² (1,688 sq ft) of living space, 6 supply air vents, 5 exhaust air vents, 2 silencers, installation using flat ducts on the raw ceiling, Vaillant recoVAIR 260/4 E (central controlled residential ventilation system with heat recovery and humidity recovery), delivery and installation, price July 2015 by the developer: €10,680.00.
I am familiar with a comparable project, slightly larger in scope (2 full floors + attic), round ducts in concrete ceiling, approximately €12,000, spring 2015.
PS. Please always provide the date of the quotation, as prices change over time.
nordanney17 Dec 2015 14:01Vallox ventilation system ValloPlus 510 SE for 250 sqm (2700 sq ft) living area. (300 sqm (3200 sq ft) building footprint), installation of ducts in the concrete ceilings.
Price mid-2013 approx. 11,000 EUR plus a few minor additional costs, 8 exhaust and 9 supply air outlets, higher-quality silencers, stainless steel grilles on the facade.
Price including installation
