ᐅ Are there versions of IKEA PLATSA with soft-close drawers?
Created on: 17 Aug 2022 10:27
FELIXTA
FELIXTA
17 Aug 2022 10:27
I am currently looking into the PLATSA series from IKEA and considering building a custom shelving system with drawers. I am particularly interested in whether IKEA offers versions of PLATSA that come factory-equipped with soft-close drawers.
My question is: Are there official or unofficial variants, sets, or accessories from IKEA that include PLATSA drawers with a soft-close mechanism?
I want to know if it’s possible to get the convenience of soft-close functionality directly when ordering, or if you generally need to rely on retrofit solutions.
Does anyone have experience or relevant knowledge on this? Thanks in advance!
floga
17 Aug 2022 11:42
Hi FELIXTA,
I can definitely relate to your search. I’ve also spent a long time considering how to upgrade the system – the soft-close feature really makes a difference in daily use, especially with open-plan living spaces.
So far, I haven’t been able to find any official IKEA versions of PLATSA with soft-close. The drawers at IKEA usually operate in a traditional way with a simple slide, without any damping mechanism.
There might be differences depending on certain drawer models or colors, but from what I’ve researched, all PLATSA drawers come standard without soft-close.
If you don’t want to miss out on the convenience, the only option in my view is aftermarket upgrades.
I’d also be interested to hear if anyone here has successfully retrofitted soft-close, as I’m a bit concerned about installing dampers on an IKEA system like this – you wouldn’t want to worsen the sliding quality or even damage the drawers.
I hope this helps you a bit!
naujon
18 Aug 2022 09:06
Good morning FELIXTA and all interested readers,
to properly address the topic of PLATSA drawers with soft-close functionality, let me briefly explain:
- IKEA does not offer PLATSA drawers with built-in soft-close mechanisms as standard. These are usually simple drawer slide systems that are neither damped nor self-closing.
- If you want to upgrade the drawers, soft-close fittings from third-party manufacturers can be used. There are three important factors to consider:
- Compatibility with drawer dimensions and installation
- Compliance with load capacities
- Ease of installation without damaging the PLATSA units
- The retrofit is usually done on the drawer slides themselves or on the hinges, depending on the system. In the case of PLATSA, these are mostly drawer slides that can be fitted with suitable soft-close mechanisms separately.
- There are even various guides and material lists available online that describe which soft-close adapters are recommended. These are generally not from IKEA.
Conclusion: IKEA PLATSA drawers do not come with soft-close as standard. Those who want soft-close need to retrofit it themselves and should pay attention to choosing compatible, suitable products. IKEA does not offer a direct solution.
If you like, I can also provide tips and advice on installation.
Gafiel
18 Aug 2022 20:54
Hello FELIXTA,
I would like to add some technical details to the discussion that I believe can be very helpful when considering soft-close drawers for PLATSA:
PLATSA typically uses standard full-extension slides without damping. The included runners are not designed for a soft-close function, neither mechanically nor in the guide system.
floga schrieb:
There may be differences with certain drawers or colors, but based on my research, all PLATSA drawers come standard without soft-close.
I can confirm this. The only modification IKEA might offer is possibly soft-close hinges for doors, but there are no damped slides for drawers in the PLATSA series.
If you want damping, you have these options:
- Retrofit soft-close mechanisms that are specifically made for simple drawer slides. These are usually attached to the side of the drawer or installed in the runners afterward.
- Complete replacement of the slides with high-quality soft-close slides (e.g., Blum or Hettich), but you must carefully check whether the drawer dimensions and fittings are compatible.
- Installation must be done with attention to precision, as improper alignment can cause the soft-close mechanism to malfunction or the drawer to stick.
I would also ask what kind of application you plan for the PLATSA drawers – are they for self-built shelves in living rooms, workspaces, or kitchens? Depending on the use, the effort and benefit of soft-close retrofitting can vary greatly.
If you like, I’m happy to help you find a suitable solution, including sources for compatible soft-close retrofit kits.
