ᐅ Are there any upgrades available for IKEA BESTÅ hinges to achieve smoother operation?
Created on: 14 Jul 2016 18:23
jerry32Hello everyone,
I have a question that might concern some of you with similar IKEA furniture: Are there any upgrades or retrofit options for the hinges of the IKEA BESTÅ units to make the door movement smoother and quieter?
The hinges are already soft-closing by default, but I still find the closing somewhat harsh and less gentle than I would like for a living room piece. I have been wondering if there are third-party products that are compatible or if simple measures like different damping inserts, special lubricants, or modifications to the hinges could bring noticeable improvement.
I am especially interested in practical experiences, technical suggestions, and any tips regarding compatibility issues.
Thanks in advance for your advice!
jerry32 schrieb:
Are there any upgrades or retrofit options for the hinges of the IKEA BESTÅ modules to make the door movement smoother and quieter?Hello jerry32,
your question is very well posed, and I’m happy to provide you with a comprehensive answer.
The hinges of the BESTÅ series actually come with a built-in soft-close function designed to prevent the doors from slamming shut. However, these are not always perfectly calibrated to the door’s own weight or usage, so the feel may vary.
One way to achieve smoother operation is to use special silicone damping inserts in the hinges, if compatible. Unfortunately, IKEA does not offer official “upgrades” in the form of improved hinge models for BESTÅ, but there are third-party suppliers who provide replacement dampers or complete hinge mechanisms that can sometimes be easier to adjust or provide stronger damping.
For lubrication, it’s best to use products specifically designed for hinges, such as Teflon or silicone spray, since they have long-lasting effects and do not attract dust. Some users also report better smoothness if the hinges are cleaned occasionally and then treated with such a lubricant.
If you are handy, you can also try fine-tuning the existing hinges. Some models allow adjustment of the opening resistance and damping via small screws.
If you like, I can also put together a list of possible products and sources.
I hope this already helps you!
jerry32 schrieb:
I have been wondering if there are third-party products that are compatible or if it’s possible to achieve a noticeable improvement with simple measures like different damping inserts, special lubricants, or modifications to the hinges.Good morning jerry32,
as a supplement, I would like to provide a brief guide and some technical tips on how to improve the door movement in the BESTÅ system:
- Cleaning: Start by thoroughly cleaning the hinges. Dust and dirt in the moving parts can significantly worsen the door operation.
- Lubrication: Use a silicone or Teflon spray for the hinges, never oil, which can become sticky over time. This keeps the movement smooth and long-lasting.
- Damper replacement: There are replacement dampers specifically made for IKEA BESTÅ hinges, such as those from Blum or Häfele, which can sometimes be adapted. These are usually of higher quality.
- Adjustment: Use the adjustment screws on the hinges to align the door precisely, which makes closing easier and reduces stress on the damping mechanism.
It is important to carefully check which hinge model is installed beforehand (mostly clip-on with integrated soft-close), as not every damping technology fits every hinge.
Summary:
- Clean
- Lubricate
- Adjust
- Optional: Replace dampers or use high-quality third-party hinges
This should help significantly improve the door operation. If you like, I can provide specific sources to purchase these parts.
Katau schrieb:
One way to make the closing smoother is to use special silicone damping inserts on the hinges, provided they are compatible.flope60 schrieb:
There are replacement dampers specifically for IKEA BESTÅ hinges, such as those from Blum or Häfele, which can sometimes be adapted.From a technical perspective, the following points are important:
- The original BESTÅ hinges are designed for the furniture’s weight and door size, with a built-in soft-close function.
- Damping systems from other manufacturers may offer better cushioning but are often not directly compatible and require modifications.
- Anyone seeking an upgrade should first check the hinge mounting type (e.g., 35 mm (1.38 inch) drilling, installation method).
- It is recommended to clean the mechanism and apply appropriate lubricants (silicone-based).
- Screw-on damping inserts (also called “bumpers”) made of silicone or rubber on the inside edges of the doors can also help reduce noise and impact.
Conclusion: Upgrading by directly replacing with high-quality hinges from other brands involves technical effort and is not generally recommended. In practice, a combination of well-maintained original hinges, suitable lubricants, and additional soft dampers often achieves the best improvement.
