ᐅ Are there special adapters available for Ikea PLATSA shelving units?
Created on: 15 Apr 2023 09:23
deniz_elHello everyone,
I am currently planning the setup of a new living room with Ikea Platsa shelving units and wondering if there are specific adapters or connectors designed explicitly for the PLATSA series. I am particularly interested in adapters that allow you to securely join different modules to create taller or wider constructions without compromising stability.
Does anyone have experience with these special PLATSA adapters? Are there any recommendations or essential tips to keep in mind when purchasing, especially if you want to combine the shelves flexibly?
Thank you in advance for your help!
Hello deniz_el,
Regarding your question about special adapters for Ikea PLATSA shelves: Basically, Ikea has designed the PLATSA series so that the modules can be combined quite flexibly. However, there are no specific “adapters” in the traditional sense that act as connectors between modules.
What Ikea offers instead are various connecting elements and accessories to securely join and install the modules:
- Special angle brackets for easy connection of cabinet units
- Connecting rods and screws for stability when stacking
- Wall mounts to secure larger constructions
My advice: When combining modules, pay attention to proper fastening and definitely use the wall mounts – this greatly increases stability.
If you plan taller shelving units, I would recommend not only connecting the individual modules but also mechanically fixing them to the wall.
In summary: There are no special “adapters,” but there are plenty of accessories to ensure safe assembly.
to clarify the topic a bit: The PLATSA series is designed to be modular and flexible. Therefore, the product designers avoid complex adapters that fit directly between the modules.
It is important to use the connectors recommended by the manufacturer during assembly, which are included in the individual sets or may be available separately. These ensure a stable connection.
However, if you are looking for a specific connection between two modules that is not provided for, it might be possible to use universal furniture connectors or brackets available at hardware stores. These, however, are not officially supported by Ikea and should be checked for load capacity.
In short: There are no specific Ikea adapters for the PLATSA series, but there is sufficient connecting hardware, and external furniture connectors can also be used for custom solutions.
I would like to discuss this topic in more detail, as the question about "special adapters" touches on an interesting point that many people consider when buying or modifying PLATSA shelving units:
Ikea does offer a range of connectors for the PLATSA series, which are mentioned in the assembly instructions – including screws, back panels, corner brackets, and connecting rods. However, these are not referred to as "adapters." There are no custom-made adapters in the sense of modular plug-in connectors or similar components that function like modular building blocks.
Important to know:
- The connectors primarily provide stability, ensuring that multiple shelving modules do not come apart when stacked.
- Some modules can only be connected at the corner to a limited extent. The connection points there are limited.
- For especially large or tall configurations, Ikea recommends securing the units to the wall – there are special wall anchors included or available separately for this purpose.
If you are planning a particularly customized solution, you can certainly supplement with universal furniture brackets or custom-made adapters made from wood or metal. It also depends greatly on what exactly you intend to do.
I would be interested to know: Are you planning a large, complex setup or a simple combination? Which modules do you want to connect? Then I might be able to provide more specific help.
Important to know:
PLOMA schrieb:
I’m interested to know: Are you planning a large, complex unit or a simpler combination? Which modules do you want to connect? That way, I might be able to help you more specifically.Thank you for the detailed response, PLOMA!
I plan to combine different PLATSA carcasses stacked vertically and arranged side by side to create an integrated wall storage system that also includes some drawer and flap door elements. I want to keep the shelving as stable and torsion-resistant as possible because the construction will be partly fixed to the wall, but mainly the connection between the modules themselves is important.
Can you provide recommendations on how to best secure such a combination regarding the connections between the modules? Are there any recommended screw connections or accessories that have proven particularly effective?
Additionally, I am interested to know if there are part numbers for such connector elements in the PLATSA series that can be ordered separately if new or additional connecting pieces are needed.
deniz_el schrieb:
Can you give recommendations on how to best secure such a combination regarding the connection of the modules to each other?For your planned wall unit, it is indeed best to use the connection screws and brackets provided by the manufacturer. Make sure to attach the connection points as close as possible to the module joints.
- Use the supplied metal fittings or standard furniture brackets that are strong enough.
- Add additional cross braces if the width becomes very large.
- Wall mounts are essential for stability, even when connecting modules together.
deniz_el schrieb:
Are there recommended screw connections or accessories that have proven especially reliable?Ikea supplies connection fittings with screws for PLATSA. You should definitely use these as they fit precisely. External steel furniture brackets can be used as supplements, especially if you want the shelving unit to be not only space-saving but also particularly load-bearing.
Regarding part numbers: Ikea usually lists item numbers for connection sets in their accessories shop, which you can find based on the product details on the Ikea website.
