ᐅ Are there replacement panels for KALLAX backs that provide better sealing?
Created on: 30 Oct 2020 19:27
Ray66
Ray66
30 Oct 2020 19:27
I have a specific question regarding IKEA’s KALLAX shelves, particularly about the back panels. I noticed that the standard back panels do not provide an optimal seal in my application, which involves somewhat higher moisture levels (for example, near plant stands or as a room divider that is occasionally exposed to increased humidity). This unfortunately allows moisture to penetrate and dust and dirt to accumulate behind the panels.
My main question is: Are there replacement sets or alternative back panels for KALLAX shelves that offer better sealing? I am especially interested in options with improved moisture and dust resistance that are easy to install and provide additional protection to the shelves. Perhaps there are also specially designed sealing strips or similar components that can be retrofitted.
I would like to know if anyone is familiar with such solutions or has installed them personally. Any tips on materials and experience regarding durability would also be greatly appreciated.
Thank you in advance for your input!
GiRoyce
30 Oct 2020 20:13
Hello Ray66,
I find your question very interesting and well formulated – thank you for providing detailed information about the issue! Your concern about better sealing the back panels of KALLAX shelves is understandable, as the standard back panels are usually made of thin particleboard or hardboard, which are not really designed to withstand high moisture exposure.
Regarding replacement kits in the strict sense, I can say that IKEA itself does not offer specially sealed back panels. However, there are some solutions available from third-party suppliers in the accessories market:
1. Back panels made of plastic sheets (e.g., PVC or acrylic) – these are water-resistant and can often be mounted with screws or clamping profiles.
2. Plywood or multiplex back panels that you can customize yourself and then seal with special silicone sealants.
3. Sealing strips made of rubber or foam, which are applied to the edges to seal the gap between the back panel and the cabinet.
If you prefer a simple retrofit, I would recommend replacing the original back panel with a water-repellent board and applying silicone sealant on the edges.
It is important that the back panel not only seals but also stabilizes the shelf – so pay attention to sufficient material thickness.
If you want, I can gladly provide you with some sources and detailed installation instructions.
Best regards!
dijan
31 Oct 2020 08:46
GiRoyce schrieb:
There are some solutions available from third-party accessories:
Hey Ray66 and GiRoyce, I really like your discussion! 🙂 I once converted a KALLAX into a mini greenhouse replacement, and here’s what I did: I cut flexible plastic sheets to size and fixed them with strong Velcro straps. No drilling, no screws, which made for easy swapping and provided decent sealing against moisture and dust.
What was important to me was that the back panel not only offered good protection but could also be quickly removed if I wanted to upgrade or clean it.
Maybe a DIY approach like this could work for you, especially if you don’t want to permanently drill or want to be able to restore the shelf later.
From my experience, a bit of extra humidity isn’t a big problem for KALLAX, but with constant moisture or actual splash water, even a better back panel alone won’t be enough. In that case, I would recommend a full enclosure or finding a different storage location.
Looking forward to hearing what you decide! 😉
kibutar
1 Nov 2020 12:52
Ray66 schrieb:
Are there replacement sets or alternative back panels for KALLAX shelves that provide better sealing?
Hello Ray66,
to answer your initial question from a more technical perspective:
The standard back panels of KALLAX are, as mentioned, made of thin hardboard (about 3mm (0.1 inches)) and are really not designed for damp environments. If you are looking for better sealing, you should consider several aspects:
1. Material choice: Plastic panels such as ABS, PVC, or HPL (High Pressure Laminate) are significantly more resistant to moisture and provide better barrier properties than simple wood-based materials.
2. Fixing method: Since KALLAX back panels are usually just clipped or slid in, you will need a solution that either minimally modifies the existing carcass (e.g., drilling holes for screws) or uses a clamping technique.
3. Sealing: Proper sealing is achieved using sealing strips (door seals, foam rubber strips, closed-cell seals) at the edges between the back panel and the shelf frame. Without these seals, even with better materials, there will still be gaps where moisture can enter.
4. Load capacity: The back panel stabilizes the shelf and prevents twisting. If you replace it with thinner materials or plastic without reinforcements, the shelf may become less stable.
In summary, to my knowledge, there are no official replacement sets from IKEA that offer better sealing. However, custom solutions or cut-to-size panels made from the mentioned materials can be found in specialized furniture accessory stores or can be made to order.
One more tip: If the back panel is mainly meant to protect against dust rather than water, adhesive sealing tapes, which are readily available online, may be sufficient.
I would be interested to know how much moisture you are expecting? Is this occasional or actual continuous exposure to water?
This greatly influences which solution makes sense.
Best regards!
