ᐅ Are there reinforced shelves available for Billy bookcases?
Created on: 27 Dec 2023 08:23
Iskander1
Are there reinforced shelves available for the popular Billy bookcases from IKEA?
I plan to heavily load my Billy bookcase with heavy books and binders, but I want to prevent the shelves from bending or even breaking. I am aware that the standard shelves are quite thin and flexible under heavy loads.
Therefore, I am specifically looking for reinforced or thicker replacement shelves offered either by IKEA or third-party suppliers. Details such as material thickness, maximum load capacity, compatibility with standard Billy bookcases, and whether the fixing points are compatible would be helpful.
Perhaps someone has practical experience or recommendations for particularly sturdy alternatives that fit without major modifications. Thanks in advance for your insights!
Fitigu
28 Dec 2023 07:18
Iskander1 schrieb:
Are there reinforced shelves available for the popular IKEA Billy bookcases?
In my view, a very well-researched initial question.
IKEA does not officially offer thicker or reinforced replacement shelves. The load capacity limit is about 30 kg (66 lbs) per shelf in the original condition, which is often insufficient for bookcases.
The most practical solution is to create custom boards made of plywood or MDF with a thickness of at least 18 mm (0.7 inches). The boards must be cut and drilled with millimeter precision to be compatible with the shelf pins in the Billy.
As an additional tip: for better stability, it is recommended to install metal shelf supports screwed into the side panels to prevent sagging.
Those who do not want to modify the shelves themselves can alternatively use tuned-up rack kits from the DIY market that include metal reinforcements – however, these are rarely designed specifically for Billy and require adjustments.
I am not aware of a complete aftermarket solution with reinforced shelves made specifically for the Billy system.
Jensson
28 Dec 2023 09:36
I would like to add a brief guide here in case someone wants to build reinforced shelves for the Billy bookcase themselves:
1. Material choice: Use plywood or MDF panels with a minimum thickness of 18 mm (0.7 inches). These materials are more stable than the original particleboard shelves.
2. Cutting: Have the panels cut to size, exactly matching the dimensions of the Billy bookcase (usually 80 cm (31.5 inches) or 106 cm (41.7 inches) wide, and 28 cm (11 inches) deep, depending on the model).
3. Fixing: It is important to use the original shelf supports or drill small holes for the shelf pins. Alternatively, metal brackets can be attached on the sides for extra support.
4. Edges: Edge banding or paint protects against moisture and provides a neat finish.
5. Assembly: Carefully insert the shelves and avoid overloading them until they are securely in place.
For heavier loads, I recommend choosing a bookcase with a higher weight capacity. This guide is helpful if you only want to moderately reinforce the Billy bookcase.
TEOZAR
29 Dec 2023 08:52
benon schrieb:
Many users opt for plywood or MDF boards of appropriate thickness (e.g., 18-22 mm (0.7-0.9 inches)), which they cut to size and adjust at the drill holes.
I can only confirm this. Besides the material, you should also make sure that the locking cams fit securely.
There are suitable spare parts available on the market that can be combined with reinforced dowels or metal-reinforced fittings.
If you prefer not to drill yourself, some carpentry workshops offer affordable rework services.
This helps you avoid unnecessary effort and ensures maximum stability.
