ᐅ Are there any solutions to prevent pressure marks on KALLAX units placed on soft flooring?
Created on: 10 Apr 2018 18:07
Daaidan
Hello everyone, I have a KALLAX shelf from IKEA standing on a relatively soft floor, specifically on a vinyl floor with some padding underneath. Unfortunately, the weight of the shelf is causing indentations in the floor, which I would like to prevent. My question is: Are there specific products or effective protective measures that can be placed under KALLAX shelves to protect soft flooring? I’m looking for solutions that genuinely work and are not just compromises. Has anyone had experience with this or can provide specific recommendations? Thanks in advance!
Hello Daaidan, I solved the same problem by simply using non-slip felt pads that are extra wide (about 10cm x 10cm (4 inches x 4 inches)). They have a rubberized backing to prevent slipping. They work great on my soft vinyl flooring and there are no more pressure marks. You can find them online by searching for terms like "extra wide non-slip furniture pads."
Daaidan schrieb:
How large are these pads usually?Felt pads for chairs typically start at a diameter of 2 cm (1 inch), but there are also rectangular or square ones with edges up to 10 cm (4 inches) long. For KALLAX, you can simply place several side by side or buy larger sheets and cut them to size.
Daaidan schrieb:
Are there also non-slip versions?Yes, some have a rubber or PVC coating on the underside that prevents slipping. This is definitely useful on vinyl flooring.
And hey, take it easy – you want to keep your floor happy! :-)
