ᐅ Are there installation aids available to simplify the hanging of IKEA Metod cabinet doors?
Created on: 16 Oct 2021 19:07
haukemu
haukemu
16 Oct 2021 19:07
I am currently facing the task of fitting several IKEA Metod kitchen cabinets with the matching door fronts. I have noticed that hanging the Metod doors can be quite tricky, especially when working alone or if the doors are somewhat heavy.
My question is: Are there specific mounting aids or tools available that make it easier to hang and align the IKEA Metod door fronts? Perhaps accessories that speed up the process or reduce errors?
I would like to know if anyone here in the forum has experience with such aids, which solutions have proven effective, and if there are any “tricks” from everyday trade practice to make fitting the door fronts more time-efficient and ergonomic.
Thanks in advance for your insights and tips!
maugi
17 Oct 2021 08:41
haukemu schrieb:
Are there any specific mounting aids or tools that make it easier to hang and align IKEA Metod cabinet doors?
Hey, that’s a really good question! The Metod doors can be tricky sometimes, especially when you’re trying to hold them with one hand while tightening the screws 🙃.
I’ve heard about so-called door holders or mounting clips that you can temporarily attach to hold the door in place while you screw it in. Also, I always recommend having a helper for projects like this – there’s nothing better than someone holding the door while you adjust it.
If you’re working alone, try supporting the door from behind, for example on a box or a thick book. Then you can use a magnetic pickup tool to position the hinges. A screwdriver with a magnetic tip also helps a lot!
Currently, there aren’t any official IKEA mounting aids specifically for the door fronts, but I’ve seen so-called “mounting aids” on Amazon and similar sites that act as small positioning holders to keep the door steady. I’m still testing them myself – if you’re interested, I can share my experience 🤓.
gadalu
18 Oct 2021 10:32
haukemu schrieb:
Are there any specific installation aids or tools that make it easier to hang and align IKEA Metod cabinet doors?
Regarding installation aids for IKEA Metod cabinet doors:
Basically, IKEA does not provide any dedicated tools specifically designed for hanging the Metod doors. The included hinges have a clip-on function that makes it relatively easy to hang the doors once you get the hang of it.
- For installation, I recommend working in a well-lit area and adopting a position that is gentle on your back, since holding the doors and adjusting the hinges alone can be a bit awkward.
- Temporary supports, such as small wedges or site-made braces, can help hold the door in place during screw mounting.
- Some tradespeople also use extra helpers or simple homemade supports made from wooden strips or clips to brace the door.
- Additionally, there are universal installation aids for cabinet doors available from third-party suppliers that use adjustable arms to hold the door in position, freeing both hands.
For multiple installations, I suggest a systematic approach and preparing all hinges properly (adjustment, alignment) before hanging the doors. A suitable cordless drill with adjustable torque makes handling much easier.
If desired, I can gladly provide more detailed tips on adjusting the Metod hinges.
FLONE41
19 Oct 2021 14:52
gadalu schrieb:
Some tradespeople also use third helpers or simple homemade supports made from wooden slats or clips for bracing.
I can definitely confirm that. When I was assembling my kitchen, I ended up quite exhausted because I could only hold the doors with one hand at a time, and adjusting them was difficult.
Having a friend there helped me a lot – maybe just ask someone for short-term help!
Additionally, I later made a simple wooden jig to rest the door on while hanging it, so I could position and adjust it correctly.
This reduces a lot of stress and also prevents scratches when you lean the doors against the side.
If you plan to do this kind of assembly more often, it’s worth preparing something like that. And if you’re working alone, try to create a surface at hinge height where you can support the door; it makes things much easier.
