ᐅ Are there any instruction videos available for assembling Ikea Hemnes shelving units?
Created on: 25 Feb 2023 10:17
KAUCHRISTI
KAUCHRISTI
25 Feb 2023 10:17
I am currently about to assemble an Ikea Hemnes shelving unit and am wondering if there are any well-structured and easy-to-understand instruction videos available. The assembly manual from Ikea is quite detailed, but sometimes I find videos more helpful, especially when you want to see how certain tricks are put into practice.
Does anyone know reliable sources or platforms where you can find such videos specifically for Hemnes shelves? Perhaps from Ikea themselves or from experienced DIYers who explain the common pitfalls?
I would really appreciate any tips to make the assembly as smooth as possible and avoid mistakes.
Davidleo
25 Feb 2023 11:23
Hey KAUCHRISTI!
Yes, there are definitely instructional videos for Ikea Hemnes shelves! Especially on YouTube, you can find many great tutorials that show the assembly step by step. Some of these are even made by private users who share tips on how to tighten the screws better or the most effective order to assemble the parts.
Sometimes these videos really help to supplement the included manual – especially if you’re unsure about handling the components at first. I can only recommend: just search for "Ikea Hemnes shelf assembly" and watch the videos! Don’t get discouraged, the assembly is doable! 🙂👍
tutan
25 Feb 2023 12:04
Exactly, that’s it! 😎 Videos are often the key when assembling furniture. You can see right away how everything fits together and the best way to proceed without spending hours studying the manual.
By the way, if you get stuck, it’s best to check if there’s a time-lapse version of the assembly – it saves you time while still showing all the important steps! If you want, I can also find some favorites for you later.
KAUCHRISTI
25 Feb 2023 13:46
tutan schrieb:
If you like, I can pick out a few favorites for you later.
Thank you, that would be great! It’s important to me that the videos not only show the assembly but also focus on details – for example, the best way to secure the back panel or any tricks to make the shelf as stable as possible.
Sometimes these small details aren’t well explained in the official instructions. I would appreciate it if the videos also included tips on tools and how to avoid common mistakes. Since I don’t have much experience with furniture assembly, that would be very helpful!
Jensson
26 Feb 2023 09:32
Hello KAUCHRISTI,
I have assembled several IKEA Hemnes shelves and can recommend a brief guide that many users find helpful:
- Specifically look for videos that not only show the assembly process but also provide tips on stabilizing the unit.
- Make sure the back panel is properly aligned – it is important for stability.
- Usually, the included Allen key is sufficient, but a small hammer can be useful to gently tap in the nails for the back panel.
- Before tightening the screws, check that all parts fit correctly to avoid damage later on.
Tip: Some YouTubers show the entire assembly at real-time speed, which helps with following along even if it takes longer.
If you like, I can recommend a particularly good video that clearly explains all these points.
Davidleo
26 Feb 2023 15:07
Jensson schrieb:
Tip: Some YouTubers show the entire assembly in real time, which helps to follow along
Exactly! I’m also a big fan of that because you don’t miss any important details. For example, when assembling the Hemnes shelf unit, fitting the back panel is often tricky – if it’s not precisely aligned, the unit can wobble.
Another encouraging tip: Don’t be afraid of making mistakes! Just rewind, watch again, and keep going. You’ve got this!💪
