ᐅ Are there any IKEA PLATSA replacement parts that are commonly needed?
Created on: 18 Sep 2023 17:38
Metin
Metin
18 Sep 2023 17:38
I am currently looking into IKEA Platsa replacement parts and wondering if there are certain parts that are needed more frequently. I am particularly interested in practical experiences regarding which parts tend to require replacement most often after some use—whether due to wear and tear, installation issues, or simply because they are prone to problems.
It would also be helpful to know whether IKEA makes certain replacement parts easy or difficult to obtain, and if some parts are typically harder to source.
Does anyone have experience with PLATSA furniture in terms of replacement parts? Which parts have you had to replace? And are there any tips on which parts are better to order as spares when you first buy the furniture?
Looking forward to your insights and recommendations!
bapar
18 Sep 2023 18:07
Hello Metin,
Regarding your well-formulated question about replacement parts for IKEA PLATSA, I can share some insights as I have several units in use myself and have needed to order spare parts.
Basically, replacement parts for PLATSA can be divided into the categories of fittings (such as screws, dowels, and mounting rails), front and side panels, and internal systems (drawer slides, hinge mechanisms).
The most commonly needed replacement parts are:
- The connecting rails between individual modules, as they can easily bend or break during rearranging (e.g., when moving).
- The gliders and small plastic parts used on drawers and doors, since wear is clearly visible here. These parts often cause squeaking or sticking drawers.
- Screws for the frame elements, especially the short cam screws. These rarely break, but when something goes wrong, they are difficult to replace with standard tools.
It is notable that although IKEA does offer replacement parts, availability varies regionally. In some stores, parts must be pre-ordered, while in others they are immediately available. A small tip: these parts are not found directly in the furniture section but only at the service desk or through the online spare parts store.
Consider which modules you use most intensively. For example, if you have many drawers, I would recommend taking some small plastic gliders with you. Or if you plan to frequently rearrange, it’s useful to keep some connecting rails in reserve.
I am also curious about which specific modules you use – do you mostly have simple cabinets or those with built-in drawers and flaps? That could help me give a more precise recommendation.
Mufato
18 Sep 2023 19:42
I mainly needed replacement drawer slides for my PLATSA furniture. They tend to wear out quickly with frequent use.
The screws for the connections are also important since you can sometimes lose one during assembly or when modifying the furniture.
In general, spare parts for wear components are worthwhile, but otherwise rarely necessary.
draleo
19 Sep 2023 08:55
As a complement:
The most commonly needed IKEA PLATSA spare parts include:
- Plastic glides for drawers and doors, as these tend to wear out with frequent use.
- Connector rails and assembly hardware, which can be damaged during multiple rebuilds or transport.
In practice, it should be noted that spare parts are not always standardized, meaning different PLATSA modules may use different fasteners or mechanisms. Therefore, it is advisable to obtain original spare parts directly from IKEA to ensure proper fit.
It is also recommended to note the exact article number of the part in advance. Issues often arise because spare parts are only available through customer service and are not stocked directly in stores.
In summary:
- Spare parts related to moving components, such as drawer slides or door hinges, are most frequently needed.
- Wear on connectors and small parts is also common.
- Access to spare parts is ensured, but it is advisable to order in advance.
If an overview or guide for precisely identifying spare parts is desired, I am happy to assist.
