ᐅ Are there Ikea PLATSA furniture units that offer especially high load capacity?
Created on: 10 Oct 2018 08:27
Giancarl38
Giancarl38
10 Oct 2018 08:27
I am currently looking into Ikea Platsa furniture because I am considering purchasing a customizable storage system for my home office. It is important to me that the furniture is especially sturdy, as I need to store a lot of technical equipment and some heavy binders.
My question is: Are there any Platsa furniture variants or specific components at Ikea that offer higher load capacity? Perhaps thicker panels, reinforced constructions, or official maximum load ratings that exceed the standard?
I would appreciate any experience or additional information before I make my decision and place an order.
fiman
10 Oct 2018 08:55
Hi,
PLATSA is generally designed for typical household loads, not for heavy weights. For heavy items, you should rather use individual shelving systems with metal frames.
PLATSA components have maximum load capacities of around 15-20 kg (33-44 lbs) per shelf, no more.
keole
10 Oct 2018 10:12
fiman schrieb:
PLATSA elements have maximum loads of around 15-20 kg (33-44 lbs) per compartment, no more.
That is correct. Ikea does not guarantee high load capacity for PLATSA. For heavier items, it is better to use KALLAX or Ivar.
For PLATSA, the only solution is to reinforce the interior, add additional supports, or secure it to the wall.
putan
10 Oct 2018 11:43
PLATSA is very flexible, but it's not really designed for handling very heavy loads. 😉
If you want to store many heavy binders, I would recommend mounting it to a wall and possibly adding extra reinforcements, such as metal brackets. This way, you can make the system more stable without having to switch to heavy furniture.
It will also make the whole setup more durable in the long run.
barEsperan
10 Oct 2018 13:09
Just a quick note on load capacities: Ikea specifies a maximum load per compartment for each piece of furniture. For PLATSA, this is often around 20 kg per shelf.
If you need to accommodate more weight, you should either distribute it across several compartments or consider other product lines.
Greater stability is achieved by securing the unit to the wall. Without wall mounting, the load capacity is significantly lower.
Giancarl38
11 Oct 2018 09:31
putan schrieb:
If you want to store many heavy folders, I would recommend wall mounting and possibly adding extra reinforcements—such as metal brackets.
Thanks for the advice! My plan also includes wall mounting because the room isn’t very large and I need high stability.
Does anyone know if Ikea offers these additional brackets or reinforcements specifically designed for PLATSA, or are these usually DIY solutions using parts from hardware stores?
And one more question: Has anyone had experience combining PLATSA furniture with other Ikea series that might be more stable?
