ᐅ Are there IKEA Platsa furniture options that are space-saving for the bathroom?
Created on: 2 Feb 2018 10:12
sadimau
I am currently planning to remodel my bathroom and am looking for space-saving furniture that is still functional. I came across the IKEA Platsa range and am particularly interested in whether there are models or combinations within the Platsa furniture that are especially suitable for bathroom use, meaning:
- Resistant to moisture
- Compact dimensions with good storage layout
- As adaptable as possible to different room sizes and shapes
Does anyone have practical experience or specific recommendations on which Platsa elements are especially suitable for a small to medium-sized bathroom? Are there any limitations regarding their use in bathrooms that should be considered?
I would appreciate detailed tips or further insights to help me make a well-informed decision.
LANICOLE
2 Feb 2018 12:17
Declan55 schrieb:
A tip: Use the inside surfaces of doors for small holders; it saves a lot of space.
This is an excellent tip, which I would like to add to: Generally, the inside of doors are great for organizing small items. It’s worth using hanging organizers or small baskets to increase usable space.
Another point often overlooked when buying bathroom furniture is the ventilation of the cabinets, especially if towels are stored inside. Platsa is open enough to allow air circulation, but care should be taken to avoid trapping damp air to prevent mold.
sadimau
2 Feb 2018 12:35
Thanks already for the many helpful answers!
One more question: What about the dimensions? I have a small bathroom with a niche that is 70 cm (28 inches) wide and 200 cm (79 inches) high. I thought a Platsa unit with a width of 60 cm (24 inches) and an attachable top might fit.
Are there any known limitations or experiences regarding the height or width when mounting them on bathroom walls? Also, it would be interesting to know if the doors on these units close well and do not warp or swell due to moisture.
Gino38
2 Feb 2018 13:02
Dimensions of 60 cm (24 inches) width are quite common for Platsa and suitable for niches of the size you mentioned. There are modules available in depths of 35 cm (14 inches) and 60 cm (24 inches), so you can choose depending on how much space you have in front.
Regarding the doors: From my experience, the doors close well when the hinges are properly adjusted. However, as already mentioned, slight expansion can occur with moisture, especially on wooden edges. Regular ventilation is therefore important.
For installation, I recommend following the dimensions precisely and checking the walls beforehand to ensure that hooks or screws have a firm hold.
Merlin52
2 Feb 2018 13:27
Hello sadimau,
I would like to organize the question about suitable Platsa furniture for the bathroom a bit:
1. Moisture Resistance
- The boards are melamine-coated, which makes them water-repellent but not waterproof.
- The edges should be sealed with paint or silicone.
2. Dimensions and Customizability
- Platsa offers different widths (50cm (20 inches), 60cm (24 inches)) and heights (30cm (12 inches), 60cm (24 inches), 90cm (36 inches)).
- The modules are stackable and flexible, so you can adjust the height as needed.
- For a niche measuring 70cm (28 inches), I recommend choosing a 60cm (24 inches) module to leave some space for air circulation and allow doors to open easily.
3. Installation and Features
- Avoid placing the units in areas with direct water exposure as much as possible.
- The doors come with adjustable hinges, which is important for long-term use.
4. Storage Tips
- Use the inside surfaces of the doors for small items.
- Various inserts are available separately to make the space more efficient.
5. Practical Advice
- If you store electrical devices or sensitive items, ensure adequate ventilation!
I hope this summarizes the most important aspects clearly.
sadimau
3 Feb 2018 09:48
Thanks to everyone, especially Merlin52, for the helpful summary!
I am currently leaning towards choosing a base unit that is 60 cm (24 inches) wide and 90 cm (35 inches) high, with a 60 cm (24 inches) high upper unit placed on top to make optimal use of the vertical space.
Can someone tell me how stable this stacking is in everyday use? And what about securing the units? Do I absolutely have to fix the modules to the wall, or will they also stand securely on their own? The goal is a solution that is as space-saving as possible, but also safe.
laureo
3 Feb 2018 10:14
Regarding stability and fastening:
Platsa is basically designed as a modular system and can stand without wall attachment; however, it is recommended to fix it to the wall, especially for taller assemblies. This significantly improves stability and prevents tipping.
The connectors and screws supplied by IKEA are coordinated with each other.
For your planned combination of 60 cm (24 inches) width and stacked units, you should definitely use wall mounting, especially if you have children in the household or if the furniture is placed in a frequently used area.
Certainly, the furniture is reasonably stable when free standing, but for the bathroom, this would not be my choice to avoid damage or accidents.
