Good morning everyone,
I am currently planning a new wardrobe and wondering if the IKEA Pax wardrobes have a modular interior system. Specifically, I am interested in whether the internal components like shelves, hanging rods, drawers, or baskets can be combined flexibly to create a customized layout according to individual needs, without being limited to fixed configurations.
Are Pax wardrobes designed for this kind of flexibility, or are there mostly pre-made divisions that can only be adjusted to a limited extent?
I would be very grateful for any experiences or concrete information on how flexible the interior design of Pax wardrobes really is.
Thanks in advance!
Thanks in advance!
Hello nosi68,
to answer your question: Yes, IKEA Pax wardrobes are specifically designed for modular interior fittings. The system is based on standardized widths and heights of the carcass frames, within which you can work with various interior components.
- You get a wide selection of shelves, hanging rails, drawers, wire baskets, and even special solutions like shoe racks.
- These modules can be combined and rearranged almost freely since they rely on hanging or screw-in systems.
- Typically, you can customize your wardrobe entirely according to your needs – whether it’s a lot of hanging space, drawers for small items, or open compartments for accessories.
Regarding a common mistake: People often think they can only choose from the predefined configurations, but the flexibility is much greater. It is important that you know the exact measurements during planning so the modules fit together properly.
In summary: Pax is very adaptable and modular, ideal for individual wardrobe interior design.
LEOPAU schrieb:
Typically, you can customize your wardrobe exactly according to your needsExactly, that’s a good way to put it.
I have a Pax myself and regularly change the internal layout depending on my needs. It works without any problems.
In addition to the previous posts, it should be mentioned that the modular approach of IKEA Pax is also supported by the planner on the IKEA website. There, you can define the dimensions and then get suitable modules to choose from.
The interior fittings are not fixed but almost entirely customizable. An important point is that the modules use standardized height increments, allowing shelves or clothes rails to be positioned at different levels.
Conclusion: The modular interior fittings are a core feature of Pax, making the system very versatile.
nosi68 schrieb:
Are Pax cabinets designed for this purpose, or are there more prefabricated divisions that can only be adjusted to a limited extent?I share the view expressed in the previous answers but would like to point out critically that the flexibility does have its limits.
- Some modules are only compatible with certain carcass heights or depths.
- For more complex requirements, it can become more difficult to combine everything optimally.
- Additionally, the finished cabinet doors and shelves come in a limited range of sizes, which restricts customization beyond the standard options.
Overall, it is modular but not infinitely flexible. For more complicated requests, there may be some limitations.
neo59 schrieb:
I share a similar view to the previous responses but would like to point out critically that the flexibility does have its limits.That’s true, and your concerns are important. The system is based on a modular grid, which means it’s rare for someone to design a cabinet without any compromises. However, it remains a highly flexible system offering more than enough adjustment options for most users.
Here are a few tips to maximize the system’s flexibility:
- Pay attention to the correct combination of depths (35cm (14 inches), 58cm (23 inches)) and compatible accessories.
- Use the included pre-drilled holes to precisely adjust shelves.
- Utilize additional interior fittings such as adjustable hanging drawers or baskets.
If you consider these points, the modular interior fittings of Pax will serve you very well.
