ᐅ Are there Ikea Pax wardrobes with built-in lighting and power outlets?
Created on: 27 Mar 2021 08:12
Botan
Botan
27 Mar 2021 08:12
I am currently planning a new walk-in closet and wondering if there are any Ikea Pax wardrobe options that come with integrated lighting and power outlets.
My main question is: Does Ikea actually offer Pax wardrobe models that include built-in lighting from the factory, ideally with LED strips or spotlights, and also feature fixed power outlets so that no additional electrical installation is needed?
I imagine the lighting being mounted directly within the wardrobe frame or on the shelves, operated easily by a switch or sensor, and that there are, for example, power outlets nearby for charging smartphones or small devices.
Does anyone have experience with such integrated solutions in the Pax system or possibly suitable accessories offered directly by Ikea? Or are these components always only available as separate retrofit options?
I would appreciate any tips or information, preferably with specific product names or packaging details if available.
Parbo
27 Mar 2021 09:37
Regarding the question of whether Ikea Pax wardrobes are available with integrated lighting and power outlets, I would like to provide a detailed answer.
Ikea offers the so-called Ledberg LED strips as accessories for the Pax system, which are specifically designed for wardrobe lighting. However, these are not factory-installed inside the wardrobe but can be retrofitted—for example, mounted on the top edges or the back panels of the wardrobes.
Installation is relatively simple, but the power cable must be connected to an existing electrical outlet; the Ledberg strips come with an integrated plug, not a fixed wiring inside the wardrobe. Ikea does not sell Pax variants with built-in power outlets recessed into the wardrobe frame. Power strips or individual outlets would need to be installed and wired separately.
A common challenge in such cases is the power supply: wardrobe lighting should ideally be controlled via a separate switch or motion detector to increase convenience and energy efficiency. The Ledberg series also offers various switch options, but you need to pay attention to the appropriate cable lengths.
For installing power outlets directly into the wardrobe frame, I recommend considering external solutions or custom-made electrical components, as Ikea does not offer certified products in this area.
Also, you should be aware of the applicable electrical standards for the installation to ensure safety. If you need further detailed information on installation or technical specifications, feel free to ask.
PULAU
27 Mar 2021 11:02
Parbo schrieb:
Ikea itself offers so-called Ledberg LED strips as accessories for the Pax system, which are specifically designed for cabinet lighting.
That’s correct; in my experience, these Ledberg LED strips are the simplest way to add lighting to a Pax wardrobe, either during assembly or afterwards.
Regarding power outlets, Ikea is rather limited: there are no integrated outlets within the frame, but I have often seen customers place simple power strips or USB chargers on shelves or attach them to the inside back panel to remain flexible.
So if you’re looking for a complete solution with built-in power outlets straight from the factory, unfortunately, Ikea doesn’t offer that. You would need to turn to specialized suppliers or custom solutions.
A tip: If you want the lighting to be controlled by a touch switch or motion sensor, it’s worth purchasing a separate motion sensor module or consulting an electrician. This greatly improves ease of use.
Kabau
28 Mar 2021 07:19
Ikea does not sell Pax wardrobes with built-in lighting and power outlets.
However, you can retrofit LED lighting yourself and install power outlets separately.
Parbo
28 Mar 2021 12:48
Exactly, that is the main point. I would add that you can also use pre-made wardrobe lighting kits from Ikea – but these are always optional and need to be actively installed.
PULAU schrieb:
So if you are looking for a complete solution with power outlets built in from the factory, unfortunately you won’t find that at Ikea.
That’s accurate. I also recommend seeking professional help for the electrical installation, especially when combining lighting with power outlets. This ensures a safe, long-lasting solution.
If anyone needs detailed instructions on how to install the Ledberg LED strips inside the Pax wardrobe, I’d be happy to provide them.
