ᐅ Are there versions of Ikea Pax wardrobes with soft-close drawers?
Created on: 18 Feb 2018 09:23
yvokar
yvokar
18 Feb 2018 09:23
Hello everyone, I am currently planning my bedroom layout using the IKEA PAX system and came across the topic of soft-close drawers. Are there different types or versions of IKEA PAX drawers that come standard with a soft-close feature? If not, is it relatively easy to retrofit the regular drawers with soft-close mechanisms? I want to make sure the drawers close quietly and smoothly since this is important for use in the bedroom. Thank you in advance for your help and tips!
Germanro
18 Feb 2018 10:02
Yes, IKEA PAX drawers with soft-close technology are available. These drawers feature the BLUM Tipp-ON or BLUMOTION system, which are usually a bit more expensive. Alternatively, you can buy soft-close metal drawer slides separately and retrofit them.
fugolo
18 Feb 2018 17:47
Regarding PAX drawers with soft-close functionality, I would like to provide a brief overview:
- IKEA offers specific drawer fronts and slides with integrated soft-close mechanisms, such as the BLUMOTION slides, which enable smooth closing.
- However, these are not automatically included in the standard PAX range and usually need to be selected or purchased separately.
- For those who have an existing PAX system without soft-close, compatible soft-close slides can be retrofitted; IKEA even sells them separately.
- It is important when retrofitting that the slides fit correctly and that the drawer fronts are not too heavy, as this can prevent the damping system from working properly.
Tips:
- Measure carefully before purchasing and check whether the soft-close slides are compatible with your cabinet model.
- If you have an IKEA store nearby, you can often test the slides in person there.
I hope this is helpful!
Henryteo
19 Feb 2018 08:36
fugolo schrieb:
Anyone with an existing PAX system without soft-close can retrofit it using compatible soft-close drawers; IKEA even sells them separately.
Exactly, I bought the soft-close drawers separately and installed them myself. It works without any issues.
semuneo
20 Feb 2018 11:14
yvokar schrieb:
I want to make sure the drawers close quietly and smoothly because that is important for use in the bedroom.
I can completely understand that, as disturbing noises in the morning are really unpleasant in the bedroom. The soft-close option from IKEA PAX is a good investment to make the drawers quiet. I also found it helpful to carefully follow the assembly instructions to install the drawer slides correctly. If you are somewhat handy, retrofitting is quite feasible. If not, it’s worth contacting customer service or a professional. Good luck with your planning!
