ᐅ Are there Ikea PAX wardrobe models with adjustable depth?
Created on: 12 Aug 2023 14:07
Demianix51
Demianix51
12 Aug 2023 14:07
Hello everyone, I am currently planning a new closet system from IKEA, focusing specifically on the PAX models. My question is: Are there any IKEA PAX wardrobe models or versions where the depth can actually be adjusted within a flexible frame? I know that PAX is offered in several fixed depths (usually 35cm (14 inches) or 58cm (23 inches)), but I am looking for a closet with a depth that can be flexibly adjusted, for example, to fit exactly into a wall niche or an irregularly sized space. Perhaps IKEA offers expansion options or accessories that provide this kind of flexibility? I would appreciate any information about official products or proven practical solutions!
Jensson
12 Aug 2023 14:53
Hello Demianix51,
Regarding your question: IKEA primarily offers the PAX systems in two depths: 35 cm (14 inches) for shallower spaces, and 58 cm (23 inches) as the standard depth. There is no officially adjustable depth within a single model, as the PAX carcasses come pre-assembled and are designed for these fixed dimensions.
However, there are two options you might consider:
- Planning with different carcass depths: You can combine individual modules of varying depths to better fit your room layout.
- Modifications using back panels or plinths: Some users alter the depth by using custom-built components or IKEA accessories, but these require adjustments and are not officially supported by IKEA.
It is important that the rails for doors or drawers correspond to the respective depth, as mismatches can affect functionality. If you have a room with unusual dimensions, it may be worthwhile to use the PAX planning tool and possibly consult a carpenter for custom solutions.
Summary:
- No officially adjustable depth in the PAX system.
- Choice between 35 cm (14 inches) and 58 cm (23 inches) standard depths.
- Combining multiple modules or individual modifications are possible.
I hope this helps you with your further planning!
BOMILAN
12 Aug 2023 15:34
There is no adjustable depth for PAX. You can only choose between 35cm (14 inches) and 58cm (23 inches). Any modifications must be done by yourself; IKEA does not offer this.
Surela
13 Aug 2023 10:12
To take a closer look at the topic of flexible cabinet depth in the PAX system: Fundamentally, the PAX system is designed around modular standard sizes. The carcasses come pre-assembled in standardized dimensions – depth is a fixed value and cannot be adjusted.
Why is this the case? All internal fittings, shelves, hanging rails, and especially the doors (whether sliding or hinged) are precisely matched to this depth. For sliding doors, for example, a specific wall clearance and track alignment must be exact, so a flexible adjustment does not make much technical sense.
Nevertheless, there are different approaches to indirectly modify the dimensions:
- You can combine individual modules with a smaller depth (35cm (14 inches)) and either leave them open or equip them with back panels to create a shallower depth than 58cm (23 inches).
- It is possible, for example by adding supports underneath or by cladding with trims, to slightly adjust the depth; however, this cannot be done extensively and comes at the cost of reduced interior space.
- Some users report personal modifications to the back panel or even splitting carcasses in half, but this requires significant experience and craftsmanship and can affect stability.
To better assess this, it would be helpful to know how much flexibility you really need. Are you dealing with just a few centimeters or larger spatial adjustments? The type of doors (sliding or hinged) and your own level of craftsmanship also play a role.
Hopefully, this more detailed explanation helps you.
BOMILAN
13 Aug 2023 10:24
Surela schrieb:
You can combine individual modules with a shallow depth (35cm (14 inches)) and either leave them open or equip them with back panels to achieve a shallower depth than 58cm (23 inches).
That is correct, but this is not an adjustment of the depth, rather a choice between two fixed sizes. Adjustment means something different.
Demianix51
13 Aug 2023 16:40
Jensson schrieb:
There is no officially adjustable depth within one model, as PAX carcasses come fully assembled and are designed to fixed dimensions.
Thank you for the clarification! So this means that the depth is basically fixed and there is no option to alter the carcass depth itself.
Surela schrieb:
Maybe this more detailed explanation will help you further.
You mentioned modifications such as cladding or altering the back panel. Does anyone have experience with these kinds of adjustments? Is it realistic to do so without significantly compromising stability or functionality?
I’m also asking because I have a niche in my apartment that is exactly 55cm (22 inches) deep, and a 58cm (23 inches) deep wardrobe would therefore stick out slightly. Are there any practical solutions to make the PAX fit roughly in such a corner?
