ᐅ Are there Ikea PAX wardrobe models with adjustable depth?
Created on: 12 Aug 2023 14:07
Demianix51
Hello everyone, I am currently planning a new closet system from IKEA, focusing specifically on the PAX models. My question is: Are there any IKEA PAX wardrobe models or versions where the depth can actually be adjusted within a flexible frame? I know that PAX is offered in several fixed depths (usually 35cm (14 inches) or 58cm (23 inches)), but I am looking for a closet with a depth that can be flexibly adjusted, for example, to fit exactly into a wall niche or an irregularly sized space. Perhaps IKEA offers expansion options or accessories that provide this kind of flexibility? I would appreciate any information about official products or proven practical solutions!
kieran
14 Aug 2023 08:50
Regarding the adjustable depth of IKEA PAX: The official dimensions are fixed, and there is no mechanism that allows for variable depth.
For niches like yours with a depth of 55 cm (22 inches), you can consider the following options:
- Choose the 58 cm (23 inches) deep frame, but keep in mind that the wardrobe will slightly protrude.
- Instead, use the 35 cm (14 inches) deep frame if the interior volume is sufficient.
- Custom modifications by external carpenters are the only option if the depth needs to be exact.
The risk with modifying the frame is that these parts are critical for stability, and the IKEA modules are not designed for depth reductions. Sliding doors in particular can become problematic.
Conclusion: Flexibility with PAX is quite limited; you either choose from the available depths or opt for custom construction.
faso31
14 Aug 2023 12:03
Demianix51 schrieb:
Does anyone have experience with such modifications? Is it realistic to do this without significant loss of stability or functionality?
I want to question this: If IKEA does not offer adjustable depth, how likely is it that DIY modifications will work well in the long term? The components are designed for stability and precise dimensions. Alterations could cause material stress or door alignment issues.
If the room depth is 55 cm (22 inches) but the cabinet depth is 58 cm (23 inches), it might be better to consider modifying the room itself (such as recessing or adding internal cladding) rather than altering the furniture.
Therefore, I would generally advise against DIY adjustments to the depth and instead suggest adapting the room measurements or the furniture system.
