ᐅ Are there better hinges available for the PAX wardrobe?
Created on: 21 Dec 2021 19:23
Juleje
Juleje
21 Dec 2021 19:23
I have a question that may have been asked before, but I want to phrase it as precisely as possible to get helpful answers: Are there better hinges available for the IKEA Pax wardrobe that are more durable or offer better functionality than the original ones?
I have noticed that the standard hinges sometimes start to creak or don’t close as smoothly after a while, especially on the larger wardrobe models with heavy doors.
Are there third-party hinges that can be installed without much effort and that improve the overall quality of the wardrobe? Or is it worth using stronger hinges for particularly heavy doors? I look forward to hearing about your experiences and tips.
SUDAN
21 Dec 2021 20:07
Juleje schrieb:
Are there better hinges for the IKEA PAX wardrobe that are more durable or offer better functionality than the original ones?
That’s a very good question, as the hinges on the PAX wardrobe can indeed be a weak point, especially if you use the doors frequently or have installed heavy fronts.
From my experience and research, there are a few options to consider:
- The original hinges are designed for regular use, and replacement parts are often available from IKEA if they become defective.
- Third-party manufacturers such as Blum or Hettich offer high-quality hinges that can sometimes be adapted to the PAX wardrobe. These hinges are often more robust and provide better soft-closing mechanisms.
- When choosing hinges, it’s important to check the hole-spacing compatibility. PAX wardrobe doors have a special mounting system that needs to be carefully verified before purchasing alternative hinges.
- For heavy doors, hinges with integrated soft-close and stronger springs are especially suitable, for example, models from Blum like the “Clip Top.”
Tip: You can also try adjusting the existing hinges, which often solves issues like creaking or misaligned closing doors.
If you want, I can create a brief guide on how to properly adjust these hinges or which measurements to consider for conversions.
Garry
22 Dec 2021 08:42
SUDAN schrieb:
Third-party suppliers like Blum or Hettich offer high-quality hinges that can potentially be adapted to the PAX wardrobe.
That’s right, the key is compatibility. IKEA uses special hinges with cup holes for its PAX systems, which don’t fully conform to industry standards but are quite close.
So, if you want to switch to stronger or more durable hinges, the first step is to measure the hole spacing and diameter of the drillings. Some Blum hinges fit almost plug-and-play if you handle them carefully.
I also recommend choosing hinges with built-in soft-closing mechanisms to minimize noise and ensure smooth closing.
In short: yes, there are better hinges, but before purchasing, carefully check your door dimensions and drillings; otherwise, installation could become unnecessarily complicated.
Espen
22 Dec 2021 10:05
Briefly regarding your question: Yes, there are better hinges for the PAX wardrobe. The best are Blum hinges with soft-close and a robust mechanism. They are more durable and work better with heavy doors.
You just need to match the hole spacing on the door with the new hinges, as this is crucial.
Naomige
23 Dec 2021 16:36
I would like to add some information here because many people are not familiar with the differences between various types of hinges. PAX wardrobes usually come with basic clip-on hinges, which are sufficient for many uses, but not everyone benefits from the soft-close feature that modern hinges provide.
If you place a high value on smooth and quiet closing, you should consider hinges with a soft-close function – these gently slow the door as it closes, protecting the mechanism and the material.
Installation is also important:
- Make sure the hinges are easy to adjust (side, height, and depth adjustments) to simplify any later fine-tuning.
- If your doors are especially heavy (e.g., solid wood fronts), hinges with reinforced springs are recommended.
In conclusion, upgrading is often worthwhile, especially if you plan to use the wardrobe for a long time. If anyone is looking for specific product recommendations, I’m happy to share some models I have personally used.
