ᐅ Are there any bamboo or other upcycling ideas for Ikea Hemnes furniture?
Created on: 4 Sep 2023 08:17
Ron-Finn
Ron-Finn
4 Sep 2023 08:17
I am currently exploring the topic of sustainable furniture design, specifically with the Ikea Hemnes series. I’m interested to know if anyone here is familiar with upcycling ideas or has even carried out projects that combine bamboo or similar natural, sustainable materials with the Ikea Hemnes range.
Bamboo is often recommended as an environmentally friendly alternative to wood due to its fast growth rate and durability. I would like to learn if there are any successful DIY projects or practical implementations where Hemnes components have been enhanced with bamboo elements or even completely redesigned.
Are there particular techniques, tips, or common challenges that usually arise with such upcycling efforts? Also, how do these combinations perform in terms of stability and durability?
I believe this topic has potential beyond just furniture building and could be of interest to sustainability enthusiasts. Looking forward to your experiences and suggestions!
warrenka57
4 Sep 2023 09:42
Ron-Finn schrieb:
I’m interested to know if anyone here has upcycling ideas or has actually worked on projects combining bamboo or similar natural, sustainable materials with the Ikea Hemnes series.
I really like that idea! I haven’t done a project with bamboo myself yet, but I once teamed up with a friend to enhance Hemnes dressers using recycled wood panels. The blend of old and new worked surprisingly well.
I can definitely imagine bamboo being used, especially as cladding or as inserts in the drawers (for example, as the base), to make the furniture visually more appealing and sustainable. I can’t say yet if it holds up over time, but bamboo’s strength should be comparable to oak or pine.
I also think it’s important to approach projects like this realistically: sometimes you need a lot of tools or expert knowledge to combine Hemnes pieces with completely different materials without compromising stability. For me, connecting some parts was more complicated than I expected.
I’m really curious if anyone here can share practical tips or personal experiences.
Joshbe
4 Sep 2023 14:33
warrenka57 schrieb:
I can also well imagine using bamboo, especially as cladding or as a component inside drawers (e.g., as the base), to make the furniture visually more interesting and sustainable.
From a technical perspective, bamboo is excellent for such applications due to its high bending strength and toughness. In combination with Hemnes, which is usually made of painted pine wood, mechanical connections using screws or wood glue are possible, provided the bamboo is properly treated beforehand (sanding, priming against moisture).
- For drawer bottoms, bamboo panels cut to size and fixed with wood glue are recommended.
- For exterior cladding, bamboo can also be attached with construction adhesive and, if necessary, secured with small staples.
However, it should be noted that bamboo absorbs moisture if not adequately sealed, which can affect materials like pine.
Regarding upcycling, it could also be interesting to use Hemnes components as the basic structure and bamboo for functional additions, such as integrated shelves or doors.
This is a complex topic, but definitely feasible with the right materials and tools.
TRADI
5 Sep 2023 10:51
I’m happy to respond again on the topic of bamboo and Hemnes, as I have completed several DIY projects involving upcycling myself.
Bamboo can definitely be used effectively, but it’s important to know that working with it differs somewhat from working with traditional wood. Here are a few tips from my experience:
- Bamboo is very hard; to achieve clean cuts, sharp tools are necessary. Carbide-tipped saw blades are ideal.
- When gluing bamboo to Hemnes parts, I recommend polyurethane wood glue, which creates a strong bond on both materials.
- It is also important to apply a clear varnish or wax finish afterward to protect the surface from moisture and increase durability.
If these points are followed, bamboo can certainly be used as decorative fronts, tabletops, or shelves and combined with Hemnes carcasses.
Don’t be discouraged if everything doesn’t fit perfectly right away—wood composite materials and bamboo respond differently to temperature changes and humidity. Flexibility during the project is helpful.
If anyone is looking for specific instructions or wants to know how I converted a sideboard, I’m happy to assist.
meGreg
6 Sep 2023 08:08
TRADI schrieb:
Bamboo is very hard; for clean cuts, you need sharp tools, ideally carbide-tipped saw blades.
Very true! If you want to achieve a bamboo look for the Hemnes, you’ll need some patience—otherwise, you’ll quickly end up with chipped areas.
I once made stylish handles for my dresser out of bamboo poles. I simply sawed the poles into small sections, hollowed them out, and fixed them with wood glue and small screws. It feels really high-quality and adds a cool natural touch.
You not only get something nice to look at but also the good feeling of using resources smartly.
I think the great advantage of Hemnes is its versatility—you can basically try almost anything, as long as you think ahead about how to join the materials.
More projects like this would be great—it makes the furniture unique!
LUISABEL
6 Sep 2023 12:16
Ron-Finn schrieb:
Are there any special techniques, tips, or common challenges that typically arise with these kinds of upcycling projects?
To conclude my view on this: From a technical perspective, when upcycling Hemnes furniture with bamboo, you need to pay special attention to two main issues:
- Material compatibility: Bamboo is denser and reacts differently to moisture compared to Hemnes wood, which can cause stress or warping.
- Joining techniques: Screwing into bamboo requires pre-drilled holes to prevent splitting.
A good approach is to modify Hemnes components so that bamboo is used only for decorative, glued-on elements, such as veneers or trim. This minimizes mechanical stress.
Alternatively, bamboo shelves or inserts can be made separately and then integrated into Hemnes furniture.
The effort is quite manageable if you work with the right tools, precision, and a clear plan. If mistakes are not an option, it’s best to start with smaller trial projects.
If desired, I can also provide recommendations for surface treatments suitable for bamboo.
