ᐅ Are there any long-term user reviews or experiences with Ikea PAX wardrobes?
Created on: 10 Aug 2023 14:23
Dili60Hello everyone, I am interested in the long-term use of the Ikea PAX wardrobe system and would like to ask specifically for experience reports. Specifically: How does PAX hold up after several years of use, particularly regarding stability, material quality, door mechanics (e.g., hinges, rollers), and its adaptability or flexibility when changing the internal layout? I have already heard from some that PAX works well, but also about issues that only appear after years. I am therefore interested in real long-term everyday experiences. Does anyone here have PAX furniture that has been in use for at least 5 years or more and can share their condition, advantages, or disadvantages? Also welcome are tips on care, maintenance, or typical weak points. Thank you in advance!
I have been using PAX for about 7 years, both in the bedroom and hallway. What I have noticed over the long term is that the basic structure remains stable, provided the assembly instructions are followed carefully and the supplied fittings are used correctly.
Regarding the doors: with the hinged doors, the hinges can be readjusted after a few years, which Ikea allows through adjustable fittings. The drawer rollers are robust, though many recommend cleaning the sliding tracks occasionally to prevent squeaking or jamming.
The material quality is perfectly acceptable for the price. The surfaces show hardly any damage, even though the wardrobe is used daily. One tip: avoid placing excessively heavy loads on individual shelves, as they may warp.
Flexibility: The big advantage of PAX is actually the modular adaptability. The system can be reconfigured or expanded with additional modules as needed, which I have done twice myself without buying new units. In summary: for average home use with normal loads, I consider PAX very solid and durable.
Interesting, @JONSON. You write:
That is an important point – but I wonder how many users actually perform these adjustments and whether this might indicate a design issue that should ideally be avoided in a piece of furniture costing over 100 euros.
Additionally, a more precise assessment of material fatigue would be interesting. "No visible damage" is subjective, especially with coated particleboard, which can swell or deform over time due to moisture exposure. Stability under heavier loads (e.g., fully loaded shelves) would also be a relevant topic.
Is there anyone here who has had PAX furniture for more than 5 years in a fairly demanding environment and perhaps can share documented issues? This would add valuable insight to the discussion, focusing not only on assembly and everyday use but also on long-term material wear.
Just a thought.
JONSON schrieb:
With hinged doors, the hinges may need some adjustment after a few years
Just a thought.
I always find it amusing how many people portray PAX as a durable design classic.
It’s great that someone put it so precisely – because such feedback is actually quite rare. Based on my experience after about 6 years of heavy use (children’s room, frequently opened and closed): the construction is more functional than robust.
Sure, you can readjust it, but that’s not something you really want to have to do regularly for furniture in this price range. The doors tend to sag, and the metal connectors combined with the particleboard frame aren’t engineering marvels. For someone looking for as little maintenance as possible over the long term, solid wood furniture is a better choice.
I believe PAX is more of a piece designed for flexibility and adaptability rather than longevity over decades. Anyone seeking exactly that should keep this in mind and maybe not just accept constant readjustments as normal.
That said, for the price, it’s a clever solution as long as you are aware of its limitations.
Dili60 schrieb:
I’m interested in genuine long-term everyday experiences.
