ᐅ Are there any tips on how to protect the Pax wardrobe from scratches?
Created on: 12 Jul 2021 08:47
Ravin65
Ravin65
12 Jul 2021 08:47
Hello everyone, I recently bought a Pax wardrobe from Ikea and now I’m looking for the best way to protect it from scratches. The wardrobe is in my bedroom, where doors are often opened and closed, and things can get a bit hectic, especially when children are visiting. Are there any tips or proven methods to prevent scratches on both the doors and the side panels? I would also like to know if there are special protective films or other materials that work well without affecting the appearance. Additionally, I’m interested in any advice regarding treatment or cleaning to keep the wardrobe in good condition over the long term. Thanks in advance for your helpful suggestions!
Nigel
12 Jul 2021 09:03
Hello, the easiest way is to apply self-adhesive protective films to the sensitive areas. These are transparent and relatively unobtrusive. Additionally, you can protect delicate edges with plastic edge guards, which are available in various sizes.
draleo
12 Jul 2021 09:18
To prevent scratches on the Pax wardrobe, I recommend the following measures: - Use protective furniture films made of polyethylene or PVC that are transparent and scratch-resistant. - Clean regularly with soft, lint-free cloths to remove dirt that can cause scratches. - Avoid sharp or hard objects near the wardrobe surfaces. - Handle the doors carefully, especially around children or pets. Additionally, clean the wardrobe with neutral cleaning agents—abrasive or harsh substances can damage the surfaces and increase the risk of scratches.
kemads46
12 Jul 2021 10:27
I would like to add that a proven approach to protecting the Pax wardrobe involves several steps:
1. Preparation: Thoroughly and gently clean the surface before applying any protective materials.
2. Applying protective films: Make sure to apply the films bubble-free and cut them as precisely as possible to fit.
3. Using edge protectors: Corners and edges are common damage points, so it is advisable to install flexible, transparent edge guards in these areas.
4. Optimizing handling: Children should be informed about potential damage; soft handles on the doors can also help prevent scratches.
Common mistakes include not using films or using low-quality products that peel off quickly. Additionally, abrasive cleaning agents can damage the surface. Following these points will significantly increase the lifespan of your wardrobe.
Ravin65
12 Jul 2021 14:04
kemads46 schrieb:
Corners and edges are often vulnerable to damage; it is recommended to install flexible, transparent edge protectors in these areas.
Thank you, that’s a good tip! Does anyone have experience with where to find edge protectors that really fit well and hold securely without looking unattractive on the doors? Additionally, I would like to know if these materials can be easily removed later if the protection is no longer needed.
Liduta
13 Jul 2021 07:22
Regarding your question about edge protectors, they are usually available in hardware stores or on platforms for furniture accessories. When purchasing, pay attention to the following points:
- Transparency: This keeps the protective strips visually unobtrusive.
- Flexibility: So they can adapt well to corners and edges.
- Adhesive: A high-quality, residue-free removable adhesive is preferable.
When applying, it is important to clean the surface well to ensure optimal adhesion. Many products also work well when removing them, as long as they have not been applied for too long or exposed to excessive heat.
Another tip: If you want to protect very sensitive surfaces, a thin, self-adhesive PVC film might be ideal. This is often easier to remove than edge protectors with thicker adhesive.
