ᐅ Are there any tips for perfectly adjusting Ikea Pax doors?
Created on: 3 Dec 2020 18:07
Sanus
Hello everyone, I am currently installing my Ikea Pax doors but having trouble adjusting them so that they close perfectly and align flush. Sometimes the doors stick or don’t close smoothly. Is there anyone in this forum with experience who can share tips on how to optimally adjust the doors of the Pax wardrobes? I am especially interested in advice on which screws to adjust exactly, whether to start at the top or bottom hinge, and if there are any tricks to compensate for unevenness without removing the doors. I would really appreciate detailed and practical tips.
JORGERON
4 Dec 2020 14:02
With my Pax doors, I have always made sure to first assemble the cabinet securely and aligned. Then:
- Top screws for height adjustment
- Side screws for spacing
- Rear screws for depth
Make small adjustments and close the door in between. This method has always worked well.
BEATE
4 Dec 2020 16:47
Another internal tip from my experience: If the doors are hard to move, check the hinges for manufacturing defects or contamination. Sometimes the cause is not just adjustment, but dirt or damaged components that obstruct the movement.
Sanus
4 Dec 2020 19:33
Thanks in advance for the helpful tips, especially the clear explanation of the different screw positions on the hinge. One more question: When adjusting the doors individually, how can I prevent the settings on one hinge from shifting while adjusting another? Is there a specific order or method to follow? And how should I handle the situation when, after adjustment, the doors are slightly misaligned and the gaps appear uneven?
pikin
5 Dec 2020 07:14
Sanus schrieb:
If I adjust the doors one at a time, how can I prevent the setting on one hinge from changing when I adjust the other?
This is a common issue when adjusting hinges. To avoid this:
- Start with the top hinge and make a rough adjustment.
- Then adjust the bottom hinge, as this is usually where the fine-tuning happens.
- During fine adjustment, only change the screws on the bottom hinge.
This way, the rough adjustment on the top hinge remains unchanged.
Sanus schrieb:
And how do I handle the situation when the doors appear slightly misaligned after adjustment and the gaps look uneven?
In this case, you should look at both doors together at the end and possibly make small adjustments to the horizontal screw on the top hinge to even out the gaps. Important: never adjust both doors simultaneously, always make targeted changes in small increments.
Jeanbar
5 Dec 2020 09:29
Sanus schrieb:
When I adjust the doors individually, how can I prevent the setting on one hinge from shifting when adjusting the other?
A good method is to approach the adjustment as a step-by-step process.
- First, adjust the top door until it fits perfectly.
- Then, adjust the second door.
- Finally, check both doors together and make fine adjustments at the shared joints.
For uneven gaps, I recommend taking your time and pausing briefly after each small correction. This helps you better assess whether the alignment appears balanced.
Friedrich
5 Dec 2020 12:53
I believe this topic should not be underestimated. Especially if you are new to flat-pack furniture, adjusting doors can be quite frustrating. Your detailed description, Sanus, also helps to better understand the problem.
I have often experienced that, in the beginning, it really is more a test of patience. Still, you shouldn’t get discouraged. In the end, it feels very satisfying when the doors close perfectly and look right.
Regarding misaligned doors: in such cases, I always check whether the cabinet itself is truly level. This is sometimes the aspect that gets underestimated. A stable, evenly positioned carcass makes adjusting much easier.
