ᐅ Are there any tips for preventing scratches on IKEA PLATSA units?
Created on: 9 May 2021 08:34
bobaplo
bobaplo
9 May 2021 08:34
I am currently setting up my new living room and have chosen the IKEA Platsa system. However, I have noticed that some of the finishes and surfaces on certain pieces of furniture and appliances seem quite sensitive to small scratches. Since I want to keep the furniture looking good for as long as possible, I have a question: Are there any tips or proven methods for preventing scratches on IKEA Platsa furniture? I would like to know how other users best take care of the surface maintenance, whether there are specific protective measures during assembly, or particular cleaning products that should definitely be avoided. I am also interested in whether special care is needed during transport or daily use to keep the surfaces intact.
I look forward to your advice and experiences!
Giagau
9 May 2021 12:17
Regarding scratches on IKEA PLATSA, I can share some practical tips from my experience that are helpful:
- During assembly, make sure all screws are properly tightened and the parts are correctly fitted to avoid any wobbling, which reduces mechanical stress on the surface.
- Use clean cloths and avoid rough sponges for cleaning. A damp microfiber cloth is usually ideal.
- Avoid harsh or abrasive cleaning agents. A mild dish soap diluted in water is usually sufficient.
- Minor transport scratches can be repaired with special furniture markers or wax repair pads available at hardware stores.
- For everyday use, I recommend not placing sharp or hard objects directly on the surface and never applying too much pressure when cleaning.
These tips not only reduce the risk of scratches but also help maintain the appearance of the furniture over time.
Rhett
10 May 2021 09:03
Giagau schrieb:
Use clean cloths and avoid coarse sponges for cleaning.
This is very important, especially no steel wool or abrasive sponges. Placing items directly on the surface is not helpful; felt pads on edges prevent scratches when moving objects.
taudi
11 May 2021 15:46
To add to this and to address the question in a more systematic way, here is a brief guide to avoiding scratches on IKEA PLATSA furniture:
1. Preparation during assembly:
- Protect your work surface with soft blankets or cardboard.
- Handle individual parts carefully to avoid impacts.
2. Assembly:
- Tighten screws without over-tightening.
- Check that all edges align evenly and sit cleanly.
3. Surface care:
- Clean only with mild, pH-neutral cleaners.
- Avoid abrasive agents (acids, solvents).
- Use lint-free microfiber cloths.
4. Protection during use:
- Avoid subjecting furniture to strong mechanical stress directly.
- Attach felt pads or protective washers to furniture that is moved regularly.
5. Transport:
- Secure furniture parts individually with padding.
- Do not store sharp-edged objects nearby.
Minor damage can be partly concealed with polish or furniture wax. My tip: choose a matching color shade when touching up to avoid visible transitions.
In conclusion: patience and care during assembly, as well as careful handling in daily use, are key to preventing scratches.
