ᐅ Are there any structural limitations with Ikea HEMNES that one should be aware of?
Created on: 16 Oct 2023 10:07
Kiboklo
Kiboklo
16 Oct 2023 10:07
I am currently planning to purchase some furniture from the Ikea Hemnes series but am unsure if there are any building-related restrictions I should be aware of before buying. Specifically, I am interested in aspects such as the maximum load capacity of the shelves and cabinets, the requirements for wall mounting, and any particular considerations regarding ceiling heights or door opening dimensions. It would also be important to know if there are any structural limitations during assembly or installation that might cause issues in small or unusual rooms. Does anyone have practical experience or in-depth knowledge that could help me avoid buying mistakes or installation problems?
Paunon
16 Oct 2023 10:12
The HEMNES series generally requires sturdy walls for mounting, which is important for tilt safety. Load capacity varies, but as a rule, the specified maximum weights according to the instructions should be followed. Ceiling height issues are rare and usually fit well in standard rooms.
GOLO42
16 Oct 2023 11:03
There are indeed some construction-related aspects to consider, especially with the HEMNES series. Firstly, the furniture is quite solid and made of solid wood, which makes it heavier than many other Ikea collections. As a result, secure wall mounting is essential, particularly for tall cabinets or large shelving units. Anti-tip devices are not optional but a critical safety feature.
Secondly, the doors of the HEMNES cabinets open outward and should have enough clearance in smaller rooms to fully open. If the ceiling height is below the standard measurement, some pieces (e.g., dressers or cabinets) may fit tightly or be difficult to slide in.
Furthermore, it is important to note that HEMNES furniture, due to its solid wood appearance, can react to moisture or UV light over time – which in certain indoor climate conditions or window placements might cause some warping. Therefore, ventilation and window position are quite relevant factors.
gasidney
16 Oct 2023 11:28
In addition to securing the walls, it is important to follow the assembly instructions precisely. With HEMNES, the assembly is usually quite straightforward, but stability can be compromised if the screws are not properly tightened. The floor should also be level to prevent wobbling.
BAUEVA
16 Oct 2023 12:45
GOLO42 schrieb:
The tip-over restraint is not optional but a safety-critical component.
This is an important point that I would like to question somewhat. As far as I know, Ikea does provide the tip-over restraints, but there is no strict legal obligation to install them in private households. Of course, it is recommended for safety reasons, yet some users do not take this instruction seriously enough. Should there be a stronger emphasis on the consumer’s responsibility here?
I also wonder whether the frequent use of solid wood, especially in HEMNES products, leads to increased long-term warping that is not adequately addressed in the instructions. Are there any practical experiences regarding this?
Lucien
17 Oct 2023 08:53
In summary:
- HEMNES furniture is mainly made of solid wood, which increases the weight and requires stable placement as well as secure wall anchoring.
- Anti-tip devices are recommended for safety reasons to prevent accidents with unstable furniture.
- Doors need sufficient clearance to open fully, especially in small rooms.
- A level and dry installation area is essential to avoid warping.
- For unusually low ceiling heights, exact measurements should be checked as rearranging might be limited.
Those who carefully follow the instructions and accurately assess the available space are unlikely to encounter many issues with HEMNES.
