ᐅ Are there any special tips for assembling large Pax wardrobes?
Created on: 17 Jun 2022 09:32
POULKEO
POULKEO
17 Jun 2022 09:32
Hello everyone, I am currently planning to assemble a large PAX wardrobe system from IKEA and would like to know if there are any special tips to consider when putting together large and complex PAX wardrobes. Specifically, I am interested in advice on how to best prepare the modules before assembly, if there are any tricks for securely fixing the wardrobes to the wall, and whether there are important details to consider when planning the interior layout to ensure everything is stable and optimally used later on. I would really appreciate your experiences and recommendations!
nonpra
17 Jun 2022 10:17
It is important to start the construction on a level surface. Always screw in the screws completely before tightening them fully. For large PAX units, I recommend always starting with the wall attachment to ensure everything is secure.
SUFOJE
17 Jun 2022 11:48
Hello POULKEO, assembling large PAX wardrobes requires patience and careful planning. It is advisable to sort all parts beforehand and check that all screws and fittings are included. Especially with large systems, wall mounting is an important safety factor, so take your time and follow the provided instructions carefully. Additionally, it is helpful to decide on the desired interior fittings before starting assembly to avoid having to make changes along the way. It’s also a good idea to perform small intermediate checks, for example, to verify that the wardrobe angles are correct or to spot any minor unevenness early on. A quick tip: if your floor is not perfectly level, placing a small shim under the wardrobes can help.
Davidleo
17 Jun 2022 13:26
Hey, I was really excited when I assembled my large PAX wardrobe! It’s a lot of fun once you get the hang of it. A tip from me: take your time and, if possible, work with a second person, especially when putting together the larger parts. The bigger cabinet feels much more stable once you securely fix it to the wall. And don’t forget to align and adjust all the doors beforehand – that makes a big difference for both appearance and function! Enjoy the build! 😊
nojaus
18 Jun 2022 08:55
Davidleo schrieb:
Hey, I was really excited when I assembled my large PAX! It’s really fun once you get the hang of it.
I can totally relate to that—assembly can quickly become frustrating if something doesn’t fit right away or if you feel uncertain. It really helped me to carefully plan each step beforehand and to allow myself breaks. Especially with large PAX wardrobes, I was worried something might tip over, so securing it to the wall was a major milestone for me. By the way, don’t hesitate to ask someone for help—it saved me a lot of stress.
Benge5
18 Jun 2022 10:12
A precise tip to add: The stability of large PAX systems largely depends on correct wall mounting. It is important to identify the wall type (e.g., concrete, drywall) and use suitable anchors or screws accordingly. For drywall, special heavy-duty anchors are recommended. Additionally, I suggest checking exact measurements and levelness with a spirit level and tape measure before assembly. Interior fittings should be chosen according to the planned weight and distributed evenly to minimize stress.
