ᐅ Are there alternative rollers for Ikea Pax sliding doors?
Created on: 29 Mar 2024 08:37
rentar
rentar
29 Mar 2024 08:37
Hello everyone, I have a specific question regarding the fittings for my Ikea Pax sliding doors: Are there alternative rollers for the sliding door systems that are compatible but possibly more durable or quieter than the original rollers? I’m looking for options because I have noticed that the original rollers often start to squeak or become difficult to move after some time. Which alternative rollers (brands, models, technical specifications) can you recommend that fit without major modifications and offer improved functionality or durability? Information on installation, dimensions, load capacity, or materials would be helpful for comparison. Thanks in advance!
peovin
29 Mar 2024 09:04
Yes, there are alternative running wheels. I have personally used some from a furniture caster manufacturer that fit perfectly. The important factors are the dimensions and the maximum load capacity. Simply measure the original wheel and then look for suitable alternatives, for example, at a hardware store or specialized online shops. Look for nylon or rubber wheels, as these are usually quieter.
Josefane
30 Mar 2024 14:22
I think the question of whether there are alternative rollers for Ikea Pax sliding doors is quite justified. However, there are a few aspects to consider:
- Compatibility: Many offers claim to be a perfect fit, but in reality the tolerances are often too large, which can lead to misalignment or increased wear.
- Material quality: Using more durable materials alone does not solve all problems. The overall construction of the sliding door also plays a role.
- Cost-benefit: Replacement rollers from other suppliers are not always cheaper than originals, but their durability can be better.
rentar schrieb:
Which alternative rollers (brands, models, technical specifications) can you recommend?
I would be interested to know if anyone has reliable long-term experience and which specific products have proven to be better than the original in comparison. Because, in my opinion, just talking theoretically about alternatives is not enough.
U
uslis47
31 Mar 2024 19:48
Hello rentar and everyone interested,
Regarding your question about alternative rollers for Ikea Pax sliding doors, I can share some experience. There are indeed replacement parts suitable for the sliding door rollers. These alternatives often come from furniture hardware manufacturers offering standardized rollers with diameters of 22–25 mm (0.9–1 inch) and ball bearings.
The important factors are:
- The load capacity: The rollers should support at least 10–15 kg (22–33 lbs) since the doors are quite heavy.
- The mounting method: Whether the rollers are fixed with a push-fit axle, screw axle, or clip.
- Roller material: Nylon or polyamide are proven options, but rubber or TPU can help reduce noise.
I have installed alternative nylon rollers with steel axles on my Pax doors, which run noticeably quieter, but precise installation is necessary to keep the doors aligned in the track.
Whether modifications are required depends on the roller type used. A direct 1:1 replacement for Ikea parts is not always available, but with careful measurement, compatible replacement rollers can be found.
If you like, I can provide detailed product recommendations and installation tips.
