ᐅ Are Ethernet ports still relevant today? Wi-Fi and wireless connections are the future!
Created on: 29 Jan 2020 21:06
Bauherr am L
Hello fellow cable enthusiasts and Wi-Fi addicts,
I already confessed in the SAT discussion that I consider coax outlets and satellite dishes completely outdated since entertainment is streamed nowadays, and I’m not planning to include them in our new build (more on that in the SAT discussion). But that’s not what this is about.
Right now, I’m trying to smartly distribute LAN duplex Cat 6a and Cat7 cable outlets throughout the rooms (1st floor: 2 kids’ rooms, kids’ bathroom, master bedroom, dressing room, master bathroom, hallway; 2nd floor: open living/dining/kitchen area, hallway, entrance area, guest restroom).
On one hand, I feel like none of the rooms really fit the outlets perfectly, like: “the desk could go here…” But what if the TV ends up in that corner instead?
On the other hand, I’m looking at our current devices and very few still have LAN ports: MacBooks, iPhones, tablets, or devices that have LAN options but mostly connect via Wi-Fi anyway, like Sonos, printers, TVs.
So the question arises whether LAN ports in rooms are still that important today. I’m not talking about the Wi-Fi access points, which of course should be connected via LAN in a convenient location, or special cases like PoE cameras and door intercoms. I’m mainly referring to the LAN outlets in individual rooms. Most end devices are mobile anyway, and the outlets will be in the wrong place 99% of the time.
I read (yes, I spent some time researching this) that the cost of LAN outlets is negligible. Well, if I install duplex outlets in all those questionable locations, the cost for switches and everything else adds up to a nice chunk.
I would be interested in your opinion on this. Since I am straightforwardly skipping any traditional TV (in our case only satellite would be possible) and the corresponding connections, wouldn’t it be consistent to also counteract the outlet overload regarding LAN?
Looking forward to your comments, thanks!
Stefan2.841 Nov 2020 18:00I will take a photo of the cabinet tomorrow. It is rather small and flat. Not much fits inside.
One cable comes directly out of the concrete ceiling without any space or junction box above. The other comes from a drywall ceiling, where I can hide cables above.
Stefan2.842 Nov 2020 07:39Then I probably have to use a spacer ring. I thought it would be enough to shorten the cable and plug it into the access point so that the cable disappears somewhere inside the access point. It's not as simple as I thought...
Stefan2.842 Nov 2020 08:02Absolutely right. I only fully understood the issue with the access points here after the concrete ceiling had already been poured. Unfortunate timing. I will need to figure out how to create enough space there.
Stefan2.84 schrieb:
Then I guess I have to use a spacer ring.From what perspective do you expect to be able to see a 3cm (1.2 inch) spacer ring at all?https://www.instagram.com/11antgmxde/
