ᐅ Are Ethernet ports still relevant today? Wi-Fi and wireless connections are the future!
Created on: 29 Jan 2020 21:06
Bauherr am L
Hello fellow cable enthusiasts and Wi-Fi addicts,
I already confessed in the SAT discussion that I consider coax outlets and satellite dishes completely outdated since entertainment is streamed nowadays, and I’m not planning to include them in our new build (more on that in the SAT discussion). But that’s not what this is about.
Right now, I’m trying to smartly distribute LAN duplex Cat 6a and Cat7 cable outlets throughout the rooms (1st floor: 2 kids’ rooms, kids’ bathroom, master bedroom, dressing room, master bathroom, hallway; 2nd floor: open living/dining/kitchen area, hallway, entrance area, guest restroom).
On one hand, I feel like none of the rooms really fit the outlets perfectly, like: “the desk could go here…” But what if the TV ends up in that corner instead?
On the other hand, I’m looking at our current devices and very few still have LAN ports: MacBooks, iPhones, tablets, or devices that have LAN options but mostly connect via Wi-Fi anyway, like Sonos, printers, TVs.
So the question arises whether LAN ports in rooms are still that important today. I’m not talking about the Wi-Fi access points, which of course should be connected via LAN in a convenient location, or special cases like PoE cameras and door intercoms. I’m mainly referring to the LAN outlets in individual rooms. Most end devices are mobile anyway, and the outlets will be in the wrong place 99% of the time.
I read (yes, I spent some time researching this) that the cost of LAN outlets is negligible. Well, if I install duplex outlets in all those questionable locations, the cost for switches and everything else adds up to a nice chunk.
I would be interested in your opinion on this. Since I am straightforwardly skipping any traditional TV (in our case only satellite would be possible) and the corresponding connections, wouldn’t it be consistent to also counteract the outlet overload regarding LAN?
Looking forward to your comments, thanks!
WingVII
30 Jan 2020 12:06
Specki schrieb:
LAN over powerline?
I’ve heard it works quite well.
We use it in the apartment with Devolo devices. It works better than Wi-Fi. However, in the new build, we planned a Cat 7A network. Powerline networking in new builds is acceptable, but I see it more as a backup option or a cost-saving measure.
Grantlhaua
30 Jan 2020 12:10
WingVII schrieb:
Cost-saving measure.
Devolo products aren’t exactly cheap either. What exactly would I be saving there?
WingVII
30 Jan 2020 12:20
Grantlhaua schrieb:
The Devolo units aren't exactly cheap either. What would I be saving there?
My developers quoted an additional cost of around €1300 for the 16 data network ports (including the switch), which comes to about €80 per port. Powerline adapters are cheaper, at about €40 per port.
Mycraft30 Jan 2020 12:23
You are still forgetting to include the outlet(s) in your calculation. These also need to be paid for if you want a powerline adapter to work.
Additionally, the switch should be excluded. You need it for powerline as well.
WingVII
30 Jan 2020 12:31
The Devolo devices are also available with a continuous power outlet. This barely increases the cost of the port. And the switch is usually integrated into the FritzBox anyway, which I have with both options. Or not?
Mycraft30 Jan 2020 12:40
Anyway, you need the electrical outlet, and the electrician certainly doesn’t provide it for free.
And if you write 16 outlets including switches = 1300, then just 16 outlets would be 1300 - X = ? In other words, the assumption that each port costs €80 is not entirely correct.
