ᐅ Are Ikea BRIMNES drawers easy to open and close?
Created on: 29 Aug 2018 11:23
Dalunu
Dalunu
29 Aug 2018 11:23
I am considering buying the Ikea Brimnes chest of drawers, but I’m not sure how smoothly the drawers operate. My specific question is: Are the drawers of the Ikea BRIMNES chest easy to open and close smoothly, or are there common issues like sticking or stiff mechanisms? I plan to use the chest mainly for frequent use in the bedroom, so smooth operation is very important to me.
Has anyone had direct experience, perhaps also regarding the long-term quality of the drawer slides? Thanks in advance for your feedback!
Hughno
29 Aug 2018 13:17
The BRIMNES drawers generally operate smoothly when installed correctly. It is important to ensure that the runners are properly aligned and not bent. Under normal use, there are usually no issues with snagging or sticking.
Giagau
29 Aug 2018 15:42
Dalunu schrieb:
Are the drawers of the Ikea BRIMNES dresser easy and smooth to open and close, or are there frequent issues like sticking or stiff mechanisms?
In my experience, this largely depends on the assembly. I recommend paying close attention to the alignment of the rails during construction. If any part is slightly crooked, it can quickly cause resistance.
Additionally, I suggest occasionally applying a light oil or a dry silicone spray to the rails to maintain smooth operation.
The mechanism itself is well-designed and can operate smoothly if installed correctly.
JOHNATHAN
29 Aug 2018 17:05
Hey Dalunu,
I have the BRIMNES in my bedroom, and the drawers slide like butter 😊! Smooth and quite quiet. I have to say I was really careful during assembly – it fits perfectly when everything is done right.
If you’re worried about sticky drawers, don’t stress. It’s usually due to self-assembly. I’d recommend testing them without any load first and tightening the screws again if needed.
Oh, and if you want to keep them running smoothly, just some occasional maintenance does the trick. Good luck with your choice!
Teonon
30 Aug 2018 08:51
I love my BRIMNES dresser!! 😍 The drawers glide very smoothly and are really easy to handle! Of course, sometimes they feel a bit stiff at first, but after opening and closing them a few times, they work like a charm!
Don’t get discouraged if it’s not perfect at the start! Just keep trying and double-check the assembly. It’ll turn out great for you!
Dalunu
30 Aug 2018 10:44
Giagau schrieb:
I recommend paying special attention to the alignment of the rails during assembly.
Hello Giagau, thanks for the tip. Could you please explain in more detail how to best check whether the rails are properly aligned?
I imagine that even small irregularities can cause problems.
And where exactly would you apply silicone spray? Only on the outer guide rails, inside, or directly on the moving parts of the drawers?
