Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Alessandro26 Jan 2021 15:22Does it say anywhere that I’m doing something different? 😉
My concern is that the relative humidity rises back up to (sometimes above) 60% after a short time.
I don’t have this issue in any other room. Not even in the small bathroom or the utility room where damp laundry is drying almost 24/7.
Alessandro schrieb:
Is it stated anywhere that I’m doing something different? 😉
My point is that the relative humidity rises back to (partially above) 60% after a short time.
I don’t have this issue in any other room. Not even in the small bathroom or the utility room where damp laundry is drying almost 24/7. Sorry to say this, but something isn’t right. This has nothing to do with residual moisture, especially since it’s only one room. There are only two possibilities: something is leaking or damp. Insulation? Plumbing? Process of elimination…
I think the issue is simply that the ventilation isn’t done properly.
Open the windows 3-4 times a day to create a cross breeze. You need cold air that can absorb the moisture. If you only ventilate from about 23.5°C (74°F) down to 21.5°C (71°F), it hardly makes any difference.
That could be accurate, you have 2-3 traps, damp towels, the plaster absorbs a small amount of water, possibly damp bath mats, etc.
In any case, ventilating to reduce humidity in the air is practically useless if you only manage to lower the temperature by 1-2 degrees Celsius (34-36 degrees Fahrenheit). Given the current outdoor temperatures, it’s hardly possible to get rid of the moisture more easily.
